Bsc621-2
jcb287
20
Ohio
Have a Viewsat Ultra behind the BSC621-2 and I have to set the LNB High to 10600 to pick up KU sats.I was having a heck of a time getting AMC-9 tuned in.Its my south sat and I thought I had a major problem someplace until I switched over to 10600 on the high side. I always thought that you set a universal LNB at 10750 for KU. Anyone else that uses the 621-2 have to set the LNB High to 10600?
That is correct. A Universal has 2 L.O. for Ku
Low L.O. - 9750
High L.O. - 10600
It uses a built-in 22KHz to switch from high to low, not to be confused with the built-in DiSEqC to switch between Ku and C Band.
Low L.O. - 9750
High L.O. - 10600
Thank you very much....they should be a little more detailed in explaining that in the instructions.:)
LNBs
Is this Birdview worth getting?
