cable run
spinnertom
Apr 1, 2009
5
dundee mich.
I have trees and there is no way to move the dish any closer then 400 ft from my disc to reciver. any help me!!!! tOM WOULD I BE ABLE TO GET HIGH DEV WITH RG11/?
Slartibartfarst
371
5
I have a feed running 475 feet from a Dish 500 to a 522 receiver. All done using RG6, 3Ghz rated, works just great.
RG11 will be OK too.
tonystewart20
42
people freak out over the distance of a cable run but honestly if everything else is good and you have the signal to lose you would be okay with rg-6. The problem is that any problems you might run into will be amplified by the longer cable run. RG-11 will help.
bross
302
New Jersey
If you're going to try it with RG-6 make sure it's solid copper core. The problem with long cable runs is voltage drop to the lnb. You need 10.5 volts at the lnb for it to operate and the receivers usually only put out about 12/13 volts, so a couple of volts drop due to resistance in the cable can cause failure. Solid copper helps because of its lower resistance.
Stargazer
16,568
340
Western WV
Another option for distance issues is to run power wire to the location of the dish or close to the dish to cut down on the coax cable distance. You would then need to have some sort of little building to place your satellite receiver and run coax wire back to the house the rest of the way. To turn the channels you would need to use UHF Pro functionality through the coax line. If you want HD you would need to find some amplifiers that take HD signals over ethernet / coax over a long distance running it through conduit so that moisture does not get to it.
pointing the dish
Ciel 2 at 129
