Came back to DirectTV Satellite - Gemini question
so2344
51
13
MD
Recently came back to DirectTV Satellite service and have two boxes, Gemini and a main HR54.
DirecTV is charging me two "TV access fees" of $10 each, but can only watch TV on the one without the server. Is there anything I can do to fix this?
It might help if you would explain the way they are setup. Are they each connected to a different TV and both connected via a coax cable? If so then they both should work. With an HR54 and Gemini...the HR54 is the server and the Gemini is the client. If they are both installed in the same location and only the Gemini is connected to a TV that is a co-located setup and if it is connected that way you should only have one $10.00 TV access fee.
2 recvrs, 2 fees ... even if one requires the other to work ... as far as I know it's always been that way, its the old mirroring fee they use to call it.
Or are you thinking that the 54 should be free and the Gemini the fee'd box, I can see that ... they change the rules when ever they want, it's hard to say what it is anymore.
I guess he could call in and inquire.
If the HR54 and Gemini are setup as co-located the HR54 can no longer show DIRECTV channels on a TV so in that situation there should only be one TV access fee. If each is setup on 2 different TV's in a normal setup then there will be 2 TV access fees. When DIRECTV changed the TV access fee to $10 per month they also eliminated the first TV access fee being free. Existing customers are not affected by the new fees so the first one is still free and all other TV fees are still $7.00 per month.
Gemini co-location is an optional "service" you can request to eliminate the receiver fee for the Hr54 or HR44. It turns the server into a headless server, much like a HS17, It is a software change on the server. The server can still output setup menus, but no programming. The server must be connected to the internet by WiFi, so that It's ethernet jack can connect directly to the Gemini. (No coax). There are ways around he Internet connection that are not approved by DirecTV. I plan to convert my HR54 to colocated configuration this summer.
I assume that is a setup DIRECTV has to perform? Or can a user do it in some way?
The installer said the HR54 (where the TV is located) is only a server. The gemini box is on another TV and works great. Will call customer service and see why we are getting two $10 charges for access.
OK if you have an HR54 at one TV that is working and the Gemini on another TV that is working then that is why you have two $10.00 per month TV access fees. An HR54 is a server but any receiver connected to a TV displaying DIRECTV channels including the HR54 gets charged a TV access fee.
That is correct, although the HR54 is only outputting a screen saying it's been setup as a server. Will call customer service again and try to get this clarified along w a potential refund.
The HR54 has always been a Server, it allows TV at it's location and serves other Genies.
They should have called them Jeannie's :)
OK that means they set it up as co-located so if you do want the HR54 to be able to watch DIRECTV content they will need to switch it to a regular setup which would require two 2 $10.00 TV access fees.
Reactions: so2344
That depends on how it is setup. If it is setup as co-located, which it seems to be, it cannot show DIRECTV content via HDMI to a TV any longer. It will only show setup screens.
Reactions: so2344
So, that would tell me that it was Used, as well as possibly a Business unit before hand, as, What purpuse would an everyday residential sub have for putting it in a different mode ...
I have been thru mine left and right, don't remember ever seeing that or stumbling on to it, several years ago mind you.
I believe the co-located setup only became available after the Gemini was released mainly because it doesn't have a port to connect coax to. At least I had never heard of it before the Gemini came along. And since the HR54 (or HR44) can't show DIRECTV content after it is setup for co-location you are not supposed to be charged the tv access fee for it which is what the OP posted about as he is being charged two tv access fees but can only watch DIRECTV on one TV. Now if has 2 TV's he wants to watch DIRECTV on the setup would need to be changed back so it can also view DIRECTV content from the HR54. For that setup he would need coax at both locations along with either a DECA to make the Gemini wired or he would need a wireless video bridge for the HR54 to have the Gemini connect to it for a wireless Gemini setup.
Specifically for if someone only has one TV and they want a DVR, 4K and the ability of having streaming apps they would want a Gemini which is the only receiver capable of 4K and the use of streaming apps. But you can't use the Gemini, which is a client, without the server (HR44, HR54, or HS17). The HS17 is probably overkill for a one TV setup so I think that may be why they made it possible for the co-location setup for the HR44 and HR54. In that setup they save the HR44 or HR54 TV access fee.
Reactions: so2344
I didn't realize they did that ...
Explain Co Locate ?
Are we talking different rooms, same house (and internet)
Or are we talking Co locate as in family members home or an RV type situation ?
I have always heard the Gemini was a a brainless drone that would connect working thru the HR54 Server ... I may be getting the names mixed up as D* has decided to name things so similar ... kinda annoying.
I had a HR54 and a Client at the end of my time with them. (client was stricly for 4k, thats why I had it)
Wow, they sure made it more confusing ... whats next for them to ad to the confusion ?
I use to know how all this stuff works, not anymore.
Explain Co Locate ?
It means the HR54 or HR44 and the Gemini are located in the same place. COAX to the HR54. The HR54 and the Gemini are connected directly to each other via an Ethernet cable. The HR54 supplies the programming directly to the Gemini via the Ethernet cable. Only the Gemini is connected to a TV though you could also connect the HR54 to the TV but the only thing the HR54 would display are the HR54 settings. You don't really need it connected to a TV because the Gemini also has the same HR54 settings available on it. The setup has to be done by DIRECTV I believe as I tried hooking mine up myself but it didn't work so DIRECTV has to do some kind of voodoo for the setup.
Reactions: Jimbo
No Wireless Gemini's ?
Yes it can be wireless but not sure it would work in a co-location setup. You would need a DIRECTV wireless video bridge at the HR44/HR54 for the Gemini to connect to wirelessly. Or an HS17 which has the wireless video bridge built into it.
Reactions: Jimbo
DirecTV’s Subscribers Number
Extra Innings
