can i get net, nebraska public tv, on g-28?
chaskuchar
807
14
saint charles, missouri
i am getting some channels on G-28 but on net there is a little signal effect but no channels found. i have a 6' antenna, dmx-741 lnb and pvr-800 receiver. charlie
You may be able to get the 3740 TP, if it's still in use. But a 6' Dish could be a little small.
The 3780 TP is Digicipher, and can not be tuned with FTA receiver.
I have the same setup as you. I can barely get nebraska pbs and sometimes not at all on my 6ft. Locks at 54qual mostly and is barely watchable. Sometimes just a hint of signal. Will always come in good on one of the 8ftrs or 10ftrs at work.
thanks for the info. i guess i will not spend too much time working on it. still getting the 6' dish aligned. finally got a reed actuator that works with the gbox so i don't have to count my punches into the left/right switch. today got most of the links set into the receiver and tonight do a blind scan on the whole sky... charlie
Point me in the right direction...
Quick Question
