Can someone confirm this is what I need to convert to SWM (picture)
Cool. Only 1 wire per DVR. That is nice....
You still need a separate coax for the the OTA tuner, right? 2 wires are better than 3.
but you don't have to run a 2nd wire. both signals (ota and sat) are combined over one coax.
Don't you need to split the coax to have one go to the separate OTA tuner once inside the house, no? How does the AM-21 get its OTA signal without a coax line going directly into its port?
If you use diplexers, one cable can be used between them for both satellite and OTA. I already had two coaxes, so use one for the satellite signal and the other for OTA.
I understand that. Don't you need to split the line once inside to get a signal to the OTA tuner? How else does the OTA tuner get its signal, especially if one is using an AM21?
yes but split it at the box so you don't have extra coax back there. make the cable real short from the diplexer to the AM21
you're welcome guys. if i can help i'll give it my best :up thanks guys......
Wipe that tear from your eye.:up
:D
99(c), 99(s), 103(c), 103(s) SL3 & SL5 tuning question
Question regarding receiver replacement
