Can you see HD channels on a SD TV
mjschuyler
45
If I had a dish at 61.5 or 121 and subscribed to the HD package, would I be able to see the HD channels with a standard receiver such as a 508 or 721 on a standard definition TV?
I have seen HD demo channels at Sears and it seems like they were on SD TV's as well as the HD TV's.
Murray
No, you need a HDTV receiver to downconvert HD for display on a standard television.
You can how ever connect a HDTV receiver such as a 6000/811/921 to a SDTV via S-Video or Composite connections. This would allow you to watch HDTV programming on a SD television. It would be down converted and actually looks very good. Usually better than SD programming on a SD Television.
I use the Composite output to connect to my VCR so I can record programming. It will record HDTV programming but of course sacrificing resolution and color brilliance when its downconverted.
But a SD receiver such as a 508 or 721 is not capable of decoding the HDTV programming signal. Thats why the HD STBs are more expensive.
