Can't figure out how to connect Vizio to second output on vip722k
budhead151
94
3
I replaced an old crt tv with a Vizio E280-A1 and the only way I get get a picture on the second output is to run the coax to a VCR first and then use composite cables to the tv. The only choices on the setup menu are component or HDMI. The old crt was set to channel 60 and so is the VCR
Good thing I kept the old VCR. Anyone have any ideas?
Enter the TV menu and search for channels. If you want to continue using 60 and if it worked well in the past search "antenna" or if you would like to try for channel 73 as suggested by Matt search "cable".
Deleted Channels
Coming back to Dish
