Channel 422.
tripod
SatelliteGuys Guru
Jan 27, 2005
148
Last nite during Tampa Bay hockey game kept getting the"searching for signal"box.Probably happened 30 times.No problem on other channels.No clouds.116 on reception.What do you think ? :confused:
Well now that I read that you have your mailing address here, not sure what would've caused the signal outage...
Do you have a dish 500 on your rv, and getting both 119 and 110? It might be that the game was on a different feed then normally.
I don't think they would've put it on a spot beam, so that's very unlikely
I get Sun sports as my regional (422) and never had a problem.Dish 500 w/300 at 61.5 for Pentagon.
another thing that can cause wierd signal losses is slight static charge going through the cables. Check your grounding block, make sure everythings in order.
942 Recording Problem
625 TV2...No Sound?
