I am new to this forum so hello to everyone! I'm sure this question has been asked, but...Is there any way to combine OTA with the DirecTV AT9 Dish. From what I have read is that you cannot combine the signal since the HD channels utilize the same low frequencies as the OTA. With that being said, I am in one of the markets where local HD is not available and trying to find a short term solution. I can get one RG-6 from my attic to the distribution panel but from there it would be great if I could diplex to my other receivers. If duplexing is out of the question are there any other recommendations? I just have one 5 lnb slimline and one antenna in the attic. I ran 2 coax to each room but did not realize that the new HD receivers use 2 coax. The 2nd was supposed to be for antenna.
Any help would be greatly appreciated.
Thanks,
Jeff (a.k.a "The Newbie")
Thanks,
	 Also, I know what the HR21 and diplexors are in your schematic but what is everything else?  The plate with 8 connections appears to be something you would use at the distribution panel which allows you to use only one diplexor at the panel.  With my current configuration (HR20-700), I would need to diplex each B-band (4 since I have 4 receivers) at the panel correct?  Is the grey box an amplifier?
