combining two antennas
caesar gdi
206
I currently have a Channel Master 4221 with a Titan UHF pre-amp. I want to add another UHF antenna. can I use a splitter in reverse to combine the two antennas?
it should look something like this
You might get away with it if the two antennas are pointed in directions more than 90 degrees apart and if all the channels are distant. What happens is that the poor reception of off beam channels from antenna A will be combined with the good reception of those channels from the correctly pointed antenna B and of course vice versa. To put it another way your success will be best if antenna A picks up very poorly the stations that antenna B is pointed towards and vice versa.
Channel Master used to make antenna couplers that would allow you to pick up one channel from a second antenna and combine it with an all channel antenna. Say it was channel 49. The coupler would only combine channel 49 from the second antenna and combine all other channels from the main antenna. They were called join-tenna couplers and came in VHF and UHF single channel versions. I think they stopped making these 5 or 10 years ago.
Actually, no, Join-Tennas are still available. You can custom order the one for the UHF channel of interest here:
Warren Electronics
Thanks for the correction Carl. One thing I did notice though is that join-tennas are no longer available for chnls 2-5. This is from the Andrew/Channel Master site.
I have 2 UHF antennas combined. They are pointing about 90-100 degrees apart.
The biggest pointer I have read is that the antennas must be the same ie add another ChannelMaster 4221.
I have 2 radioshack uhf only antennas combined and they work great. they are pointed about 150 deg apart I connect them to a channelmaster preamp (model 3041dsb) with antenna lead wire and then ran about 150 feet of RG6 to a splitter I run 3 tuners from there.
TiVo DVR questions for OTA
Help w/ choosing Jointenna
