Coolsat 5000 setup
pjzman
4
Thank you, Iceberg for the great review!!!
After read your review, I got the coolsat 5000. This is my 1st time trying to install the dish & receiver. I couldn't get any channels, In the satellite setup screen, the level bar is about 90% but the Quality only 4~7% and they are in red color not in green as yours. Why? is that because the dish didn't point to the right direction? I'm in OR. Thank you in advance!!!
Pjzman
moved off review
when you are aimed at the right satellite the bar turns green :)
What dish size & LNB do you have? Also your zip code would be good too so we can get you the right angles that the dish needs to be
The dish is 33"
LNB is Digiwave Standard Ku LNBF Digital Ready DG668
RF: 10.70/12.75 GHz
IF: 950/2150MHz
LO: 9.750/10.600GHz
Gain: 55dB
(I have clueless about these paramenters :confused: )
My zip is 97229, I'm trying to point to satellite Galaxy 3C. Which angles should the dish aim? Thank a bunch!!!
PJ
Standard KU Band lnbf use LO:10750
Universal KU Band lnbf use LO: 10600(This type of one you have)
I am sure some will give more accurate angles but here go:
Azimuth should be around 141 degrees
Elevation should be around 32 degrees
RtpiFan :)
Code:
                 Portland, OR 97229
     Latitude 45° 32.466'N Longitude 122° 49.794'W
              Sat Name Sat Lng Az(t) Az(m)    El  Skew
*** All Satellites 24W - 148W ***
          Intelsat 905   24.5W 264.0 245.9 -14.3 -44.2
          Intelsat 907   27.5W 266.2 248.1 -12.2 -44.3
         Hispasat 1C/D   30.0W 268.0 249.9 -10.5 -44.4
          Intelsat 801   31.5W 269.1 250.9  -9.5 -44.5
          Intelsat 903   34.5W  91.2  73.1  -7.5 -44.4
           AMC 12/T 11   37.5W  93.3  75.2  -5.4 -44.4
               NSS 806   40.5W  95.5  77.4  -3.3 -44.2
             Pas 3R/6B   43.0W  97.3  79.2  -1.6 -44.0
                Pas 1R   45.0W  98.8  80.6  -0.2 -43.8
          Intelsat 705   50.0W 102.4  84.3   3.2 -43.2
          Intelsat 707   53.0W 104.7  86.6   5.3 -42.6
          Intelsat 805   55.5W 106.6  88.5   7.0 -42.2
                 Pas 9   58.0W 108.5  90.4   8.7 -41.6
              Amazonas   61.0W 110.9  92.8  10.8 -40.9
            EchoStar 3   61.5W 111.3  93.2  11.1 -40.7
             Rainbow 1   61.5W 111.3  93.2  11.1 -40.7
              Nahuel 1   71.8W 120.0 101.9  17.9 -37.3
             DirecTV 1   72.5W 120.6 102.5  18.3 -37.1
                 AMC 6   72.0W 120.2 102.1  18.0 -37.3
             Galaxy 12   74.0W 122.0 103.9  19.2 -36.5
                 SBS 6   74.0W 122.0 103.9  19.2 -36.5
               GOES 12   75.0W 122.9 104.8  19.9 -36.0
                 AMC 5   79.0W 126.6 108.5  22.3 -34.2
             DirecTV 3   81.8W 129.4 111.2  23.9 -32.8
               Nimiq 2   82.0W 129.6 111.4  24.1 -32.7
                 AMC-9   83.0W 130.6 112.4  24.6 -32.2
          Brasilsat B3   84.0W 131.6 113.5  25.2 -31.6
              AMC 2/16   85.0W 132.6 114.5  25.8 -31.0
                 AMC 3   87.0W 134.7 116.6  26.8 -29.9
                  IA-8   89.0W 136.8 118.7  27.9 -28.6
             Galaxy 11   91.0W 139.0 120.9  28.9 -27.4
             Nimiq 1/3   91.0W 139.0 120.9  28.9 -27.4
          Brasilsat B4   92.0W 140.1 122.0  29.4 -26.7
             Telstar 6   93.0W 141.2 123.1  29.9 -26.0
             Galaxy 3C   95.0W 143.5 125.4  30.8 -24.6
             Telstar 5   97.0W 145.9 127.7  31.7 -23.1
             Galaxy 4R   99.0W 148.3 130.1  32.5 -21.6
       DirecTV 1R/4S/8  101.0W 150.7 132.6  33.3 -20.0
                 AMC 4  101.0W 150.7 132.6  33.3 -20.0
            Spaceway 1  102.0W 151.9 133.8  33.7 -19.2
                 AMC 1  103.0W 153.2 135.1  34.0 -18.4
                AMC 15  105.0W 155.7 137.6  34.7 -16.7
           Anik F1/F1R  107.3W 158.7 140.6  35.4 -14.7
             DirecTV 6  109.5W 161.6 143.5  35.9 -12.7
            EchoStar 6  110.0W 162.3 144.2  36.0 -12.3
            EchoStar 8  110.0W 162.3 144.2  36.0 -12.3
               Anik F2  111.1W 163.8 145.7  36.3 -11.3
         Solidaridad 2  113.0W 166.4 148.2  36.7  -9.5
              SatMex 5  116.8W 171.6 153.5  37.2  -5.9
             DirecTV 5  119.0W 174.6 156.5  37.4  -3.8
            EchoStar 7  119.0W 174.6 156.5  37.4  -3.8
 EchoStar 9/Telstar 13  121.0W 177.4 159.3  37.5  -1.8
            Galaxy 10R  123.0W 180.2 162.1  37.6   0.2
             Galaxy 12  125.0W 183.0 164.9  37.5   2.1
         Galaxy 13/H 1  127.0W 185.8 167.7  37.4   4.1
  Telstar 7/Echostar 5  129.0W 188.6 170.5  37.2   6.0
                AMC 11  131.0W 191.4 173.3  36.9   7.9
             Galaxy 1R  133.0W 194.1 176.0  36.6   9.8
                AMC 10  135.0W 196.8 178.7  36.2  11.7
                 AMC 7  137.0W 199.5 181.4  35.7  13.5
                 AMC 8  139.0W 202.1 184.0  35.2  15.3
            EchoStar 1  148.0W 213.4 195.2  32.0  22.7
            EchoStar 2  148.0W 213.4 195.2  32.0  22.7
   Satellite Finder is (c) Copyright 2004, P. Lutus
Thanks for all your help!
I'm going to get a Satellite Finder Meter and hopefully I can find the Satellite. Thanks again.
Could some give me details on how to add Nimiq1 to my sat list on my CoolSat 5000 ?
What I am doing now is using a satellite under "Dish Settings" such as a Cband bird (or other sat I don't need) that is close to the sat I want to put in. Then rename it and change the other settings as needed. Then go to "Manual Scan" and enter an active TP from Lyngsat. Now go to "Motorized Settings" and use USALS to get close and then Disecq to fine tune.
You can also move to the far east or west of the list until you find a blank spot, but I prefer the above method since your birds will be organized from east to west properly. I had to do a reset on my 4000 and I started doing it this way-much neater. Only disadvantage is you lose any pre-programmed TPs if you have to rename 2 or 3 in a row. But you can do a blind scan and get them back.
Adding Motor Positions with Channel Master
Motor Problem
