COSHIP CCTV for FTA
$585.00
magnigyro
326
Satelliteguys I need your help (how ever)
I just got a Coship marked CCTV CDVB2000....I have the remote, but...
When I press Menu: All is it in chinese!:(
How can modify the menu to change to english? Please, thanks:confused:
gyro>IF that one has the same firmware of the Coship 3188, and it's possible, I have the manual here for that one. If you press MENU on remote, the first screen will be the System Main Menu.
Scroll down to the 4TH line of options "System Settings" Hit OK. On THAT submenu>scroll down to the next-to-last option (5th one from the top of the list). That will be Language setting.
Right or left arrow on remote should scroll thru the various languages.
If that doesn't get it, go back to the first Menu screen again, next to last option from top is Factory Default. If that fails, you may have a doorstop unless you can find a manual somewhere.
On my Coship 3188C, there is only one language available: English. There are no other options.
Can you post a picture of the first menu screen?
here!
turbosat I do not want to select the fifth line, because it says 4:3 (screen I think) and my problem may be worse
Well, too bad, those menus are different from the 3188model I have. What we need is somebody who can translate the pictures!
edit: If it were me, I would have already tried all the menu lines, using the arrow buttons to see what happens, but then, I hate puzzles.
Yeah, the top line of your third image is set to Chinese. See if you can select it for another "English" option. I had the same problem with a Samsung receiver. Was sent to me in Korean but I was able to figure out how to get it set to English.
Attaboy spiff!
Maybe that'll get him going. Wonder if he knows that thing has no blindscan...
Per my Chinese co-worker:
Very well man!:) Problem solved!:up I just connect my coship and I did what your friend said and...bingo!! I´m very happy a gratefull...thanks
turbosat: I hate Puzzles too, because I can press the wrong button and I could change the format to PAL and my screen could go crazy!:rant:
Glad you got it to English. I received a box as a prize from Satellite AV and decided I wanted to reset it. Which apparently mean setting it to PAL. Unfortunately, there is no option in the onscreen menus to change the video output! Luckily, they were able to scrounge up a remote and got me back to NTSC in no time.
Locking on 83W
Lost signal for AMC4 ( 101 )
