Could someone explaing slaving a reciever?
RidgeRunner
181
37
Raymond, Maine, United States
Could someone explain slaving a reciever?
I have the equipment listed in my sig...here goes! Well for the time being I have a KU system only. I am extreamly confused on what slaving will accomplish. Also to move my dish I have to use my legacy which means I have somehow switch it over so I can see its display on my tv screen...seems kinda cumbersome just to change a channel...I know I must be missing someone. I know there are tons of people using slaved receivers, I am just not sure how to make it work I have seen the diagrams, but I am still confused. Would I just be better off getting a GBOX?
Slaving a receiver usually means that you can use the loop out of a receiver to allow another receiver to watch programs too. You can also use high frequency splitters. The drawback is the "slaved" unit can only see the same polarity as the main unit.
There are 3 ways people usually slave units.
1. They have a big dish and a 4DTV or analog box. They also have a LNB which has 3 wires to control polarity. They want to add a DVB/FTA box to the mix. So they hook it up like such.
Add a receiver
The 4DTV controls everything including polarity. The DVB box just follows along. When they blind scan, they scan one polarity, then flip the polarity on the 4DTV/analog box and rescan the other polarity.
2. You have a motorized KU only setup with a LNBF (most of the LNB's out there today). They want to add analog to an existing DVB setup. They use the loop out on the DVB box (Pansat, Coolsat, Fortec, etc) to the analog box. The DVB box does all the work and the analog box just follows along...This is how I have my setup
LNBF----motor-------------Coolsat 5000---loop out to Toshiba analog box
The CS5000 controls everything. The analog box gets whatever polarity the CS is set to
3. Option 3 is someone who has a big dish and actuator but uses a LNBF. There are two ways to do this. Either get a VBox II to allow your DVB box to control the big dish motor and slave the analog box as done in option 2. Or you could set it up as option 2 but the actuator is still controlled by the big dish. This eliminates one piece of equipment (VBox) but it is a 2 step process. You would use the analog box to move the dish to the satellite but the DVB box can get both polarity at once.
Hope this helps...or convolutes it even more
No that explains it well, my beef is if I am on one bird watching a show with my traxis and I want to switch to another show, I would have to run my setup thru a switch because I would need to call up the legacy screen to see what I am doing to switch to another bird, then hit the switch to view the traxis...I think I may be better off getting a GBOX(have heard some decent things about them! I will still keep the legacy for the analog stuff I just want a more streamlined way switching birds.
That would probably be the best option...then the analog can just follow along and the Traxis would do everything :)
Anybody using a HDTV with a FTA box?
need a installer for nc for fta
