dB levels
Billybobvi
Is there anyway to adjust the dB Levels? When I record and then play back it just isn't that loud. I have to turn up my volume. I have version 1.6 recast.
Thanks in advance,
Billy
Billybobvi,
Did you find a solution to your levels problem? I am having the same problem and what TimeTrax suggested did not help.
My recordings are way lower than the actually audio from my speakers. I made sure my Line In and Recording levels are all the way up in TimeTrax and Windows.
Maybe it's my Sound Blaster Live.
You can try the following:
1) Go into the Levels setting of TimeTrax and make sure all the inputs are correct. (It is the clickable on the main screen that says "Levels")
2) Make sure that on the Configuration screen of TimeTrax the proper recording device is chosen.
3) Go into the Control Panel, then into Sound Devices, click Advanced and check the playback properties and make sure Line-In isn't muted etc.
4) Check the recording properties and make sure Line-In is selected
Follow these steps:
1) Control Panel
2) Sound and Audio Devices
3) Advanced Tab
4) Options
5) Properties
6) Adjust Volume for "Recording" (Click OK)
A new mixer will pop up.... make sure that Line-In is selected.
Click the "X" and see if that helps.
Derek
Latest Version - 1.6 - Released
Rollback an updated version?
