Directv 18" dish alignment
corvette1991
I have my dish aligned correctly but only get spanish chanels the only hbo I get is bho latin # 511 what gives it says I have 100% signal but on the alignment screen on the dish it will only show 100 from the middle satalite the other two are 0? Could the lnb be bad? When I try other chanels it says searching for signal. I did use a compass the pole is level and azuminth is correct?:mad:
WELCOME!
I am not 100% clear on your question, but....... 18" dish? Are you talking about the PhaseI with one LNB? If so you will only pick up the satellite located where you aim; which is likely the 101 orbital slot. If you want to "see" more than one satellite, you need to upgrade to the newer multi-LNB dish setups.
Also, what package are you subscribed to?
If you have an 18" dish with one or two LNB's, you must set your receiver to the correct type of dish in the satellite setup menu. This will affect your aiming and affect how the receiver looks for and processes the sat signals.
Otherwise, it sounds like an alignment problem.
Newbie Requesting Advice/Opinions
No TV Out line for HD recevier?
