DirecTV H20-600 remote codes
CH24
Jacksonville
Hello,
I am looking to program 2 Proscan LCD TV's with my H20 remote. Does anyone know of codes to achieve this?
The TV's are a: 26" LCD from costco
37" LCD from Best Buy Possible Model # 37LC30S60
Thanks in advane for any assistance.
Kinda funny, you literally posted this 2 minutes before I was going to.
Oh well, looks like I might have to use two remotes - annoying.
I can't even get the volume to work using the button on the side of the TV!
I guess you get what you pay for.
slide the slider switch to the tv mode. hold mute and select untill light blinks twice. push 9-9-1-1 and power button. slowly channel up untill tv turns off. once tv turns off,press select, that will save the code. hope this help!
Thanks for the suggestions...neither worked however.
I pressed channel up about a thousand times and the TV never turned off.
Also tried all the RCA codes to no avail.
One strange thing, I found online to try code 10030, and when I used that, I did get some TV functions (like menu), but not volume.
touw_22
Try the 10030 code again. I tried it a couple of times and it ended up working so far on both my 26" and 37".
PM a guy named Edward here on the board, He's VERY good with this type of stuff and usually has or can get the answers.
Jimbo
WANT TO WATCH FARVE..
Help Setting Up HR-21 at Vacation Home
