DirecTV H20-600 remote codes
CH24
3
Jacksonville
Hello,
I am looking to program 2 Proscan LCD TV's with my H20 remote. Does anyone know of codes to achieve this?
The TV's are a: 26" LCD from costco
37" LCD from Best Buy Possible Model # 37LC30S60
Thanks in advane for any assistance.
Kinda funny, you literally posted this 2 minutes before I was going to.
Oh well, looks like I might have to use two remotes - annoying.
I can't even get the volume to work using the button on the side of the TV!
I guess you get what you pay for.
slide the slider switch to the tv mode. hold mute and select untill light blinks twice. push 9-9-1-1 and power button. slowly channel up untill tv turns off. once tv turns off,press select, that will save the code. hope this help!
Thanks for the suggestions...neither worked however.
I pressed channel up about a thousand times and the TV never turned off.
Also tried all the RCA codes to no avail.
One strange thing, I found online to try code 10030, and when I used that, I did get some TV functions (like menu), but not volume.
touw_22
Try the 10030 code again. I tried it a couple of times and it ended up working so far on both my 26" and 37".
WANT TO WATCH FARVE..
Help Setting Up HR-21 at Vacation Home
