ssnacks said:
I recently installed a Dish 1000 in anticipation of getting HD. I have a legacy 4000 receiver and purchased the legacy adapter. Oddly enough, whether I have the adapter attached or not, I receive 110 West odd and even on switch input 1 and switch input shows not connected. I removed the adapter and see the same thing in the setup. With or without the adapter installed, I run "check switch" as see 110 W odd and even and nothing else. When I run through the signal strength of the various satellites, I see "Wrong Sat - Echostar 110 W" for everything except for 110 W where is locks on appropriately. I tried both outputs of the dish and got the same results.
Does anyone have any suggestions as to what I am doing wrong?
I'm not a DNS super tech, but here is what I would do, and why:
Legacy Twin for 110/119
Legacy dual for 129
Legacy 21
Place DPP twin and DP dual in closet for whenever you get a 622 or some other dual tuner reciever. Legacy is cheaper and more reliable, though there is no way in hell I would pay---no
waste good money on a crappy 64 switch, even a new one. I trust those things about as far as I can throw one (right in the trash
Legacy receivers (at least some of them--granted I don't know what a 4000 is specifically--or if it supports the 129 location) will work with the DPP twin WITHOUT an adapter. I do not believe they can "see" the input port though. I KNOW they can't with a DP Adapter in the mix. I faced that on a service call and was directed by advanced tech to replace the DPP twin with a DP twin and install a DP34 switch for the wing dish.
If it were my house, I would have installed a seperate Dish 500 for the 129, that way you can "have your cake and eat it, too" regarding signal levels. That's just my preference. I'd rather not see you again on a service call, because that is what pays the LEAST. I'd much rather see you for an upgrade, or something that involves some real money. :devil: Seriously, why are you guys "settling" on the signal quality. You probably didn't "settle" when you bought your HDTV, did you? Get all the signal you can, you pay for it, you deserve it!
Found this on sadoun, says for legacy to work with NO adapter on a DPP twin that there must be TWO recievers connected. The only time I ever did this, it was for 2 9000 series recievers, and they read the DPP twin as a 64 switch. There is a picture of a legacy DPP check switch on page 7 of that document. I must need to update my acrobat reader. I'm getting a lot of funky random symbols in there, too.
Here is another document stating that some of the legacy recievers cannot "see" the 129, and it lists them. 4000 is on the list. Looks like the manual from a dish 1000, to me.
