Dish Anywhere Guide Issue
wa6rht
255
83
Modesto, CA
I'm wondering if anyone else has noticed this. Have a Hopper 3 with OTA adapter. When accessing Dish Anywhere I have noticed in the guide, on local channels, that if the "Remove SD Duplicates" is turned ON the guide removes the Satellite Version of that channel. If I turn that feature off, then it shows the Satellite version of the channel. I have attached pictures showing the guide in both configurations. If I turn the Remove SD Duplicates off then I see all the SD channels in the entire guide as well as the HD version.
The big irritation is, when I set a recording on a Local Channel, it uses the OTA which with the Hopper 3 is not a good choice.
This is with Remove SD Duplicates turned On
And this is with it tuned off.
i have the same problem with my Dish Anywhere!
Reactions: wa6rht
Hello fellow Northern Californian. I'll check when I get home tonight as I have the same setup as you. OTA antenna in the attic and Dish Anywhere with an H3.
I should also probably specify, this only happens on the web based Dish Anywhere. It's not a issue with my iPad or iPhone app.
Is The Protection Plan Neccessary
Team Summit info in the next couple of weeks
