dish netwrok and cox cable
rasputinlv
4
Las Vegas
Hi everybody.
I'm new to dish.
I'm trying to install dish netwrok dish and receiver by myself.
I already have cox cable and house is prewired.
Can I use same rf cable for cox signal and dish to come from the side of the house and come out on the same jack in the living room.
Or I have to run new cable just for dish.
my receiver is 311and I have dp34 switch.
thanks an advance
Hi everybody.
I'm new to dish.
thanks an advance
I doubt if you can use the cable for cox..use a new one according to DN specs.
I agree that you are doing overkill by keeping both Cox and Dish
If Cox did the wiring, it's almost certainly already RG6. I haven't done this but... Can't you diplex the cable signal onto the same RG6 as the satellite antenna signal?
thank you very much for responses.
House was pre-wired already, built in 97. How can I tell if it's RG6?
You need to read the coax jacket to find out the type. If you have a distribution panel with cabling exposed out the back, then read it there. Otherwise, you'll have to unscrew a wall plate and pull out enough of the cable to read what it is. It's potentially RG-59 which is marginal for satellite signals in short lengths, and probably completely inadequate at longer lengths.
Lost OTA Signal
Not receiving Ohio State-Penn State gome on ESPN2-SD
