dish netwrok and cox cable
rasputinlv
Nov 8, 2009
4
Las Vegas
Hi everybody.
I'm new to dish.
I'm trying to install dish netwrok dish and receiver by myself.
I already have cox cable and house is prewired.
Can I use same rf cable for cox signal and dish to come from the side of the house and come out on the same jack in the living room.
Or I have to run new cable just for dish.
my receiver is 311and I have dp34 switch.
thanks an advance
ercjncpr
171
southern California
Hi everybody.
I'm new to dish.
thanks an advance
I doubt if you can use the cable for cox..use a new one according to DN specs.
I agree that you are doing overkill by keeping both Cox and Dish
TheKrell
A mighty and noble race originating on Altair IV.
39,103
47,136
Fairfax, VA
If Cox did the wiring, it's almost certainly already RG6. I haven't done this but... Can't you diplex the cable signal onto the same RG6 as the satellite antenna signal?
TheKrell
39,103
47,136
Fairfax, VA
You need to read the coax jacket to find out the type. If you have a distribution panel with cabling exposed out the back, then read it there. Otherwise, you'll have to unscrew a wall plate and pull out enough of the cable to read what it is. It's potentially RG-59 which is marginal for satellite signals in short lengths, and probably completely inadequate at longer lengths.
Lost OTA Signal
Not receiving Ohio State-Penn State gome on ESPN2-SD
