Dish Pathway x 2 Issue?
reubenray
1,573
1,369
Bella Vista, Arkansas
I am on my first trip of the year in my RV and I can't get the Pathway to work correctly. The problem is the 110 satellite. Some transponders lock on and some do not. I have a clear sky. For example the USA will not work. I don't know what transponder this channel is on. Transponder 16 locks on, but I don't know what is on this transponder. Could my Pathway be going bad? Also would using the second connection help any? I have a Wally connected to this.
Edit: After checking the above sticky post USA is on 119-T21 not 110. This transponder will not lock in. I am thinking more that my Pathway is going bad.
After checking into this more I found out that the channels on even transponders work and the channels on odd transponders do not work.
What would be causing this?
Are you using a direct coax connection from the Pathway to the Wally or are you going through a port in an RV (or something similar)?
I am going through a port on my RV which worked last year. But last year I had issues with the Wally losing connection to the Dish overnight. I thought this may have been due to the GFI I was plugged into. This year I am plugged into another outlet that is not a GFI outlet. Prior to setting up the RV for the trip everything worked also while at home. If I have enough cable I will try going through the window.
I rerouted a cable through a window and everything works. I guess it is a loose connection somewhere being sometimes it works and sometimes it does not.
Can you change the four channels shown on News Multiview 201?
Hopper 3 Upgrade Software to vH390
