Dish removed on demand from my 722k
$835.00
HoppertheKangaroo18
457
661
North Carolina
I guess while I was sleeping it got a Software update because it now has newer sw and says 2026 in sys info. Here's what happens if you try to access on demand... Just goes right to my recs . You can still access photos too which is good but you have to press option 4 in menu for that. What was the point of this?
Have you checked to make sure that you're still connected to your Internet?
You do have to set up the network on the 722 for it to work. It will work with either ethernet or wifi. WiFi requires An external Dish Network WiFi USB adapter because the 722 does not have built in WiFi. After you have attached one if these you have to set it up. For ethernet: Menu, Settings, Network Setup, Test Connection.
Program Guide (110 or 119)?
Problem with DishCD 970
