Dish Wifi Adapter Kit Dual Band 802.11N
tomyo10
303
erie, pa
I bought this Wifi Adapter Kit from Amazon and installed it. It works fine for what it's supposed to do. (Dish content)
I also have the NFL Ticket on-line. Is there any way to use this adapter kit to be able to stream the Ticket to my TV from my PC that's located in another room?
thanks
The WiFi adapter will work on PCs with the proper driver, however you would need the PC to be in the same room as the TV.
I think what odst is saying is that you would have to connect video cables from computer to tv, which is an easy setup on its own, but they have to be within reach of each other.
Wifi adapter would have nothing to do with that setup
Pretty much, but if the PC needs WiFi access and has no built-in WiFi or Ethernet connectivity then the adapter can be used on the PC.
Sent from my iPhone 4S using Forum Runner
Signal Levels - What to expect
Two receiver hookup in an RV Motorhome
