DishNetwork Uplink Activity Report - 5/7/2008 1:37pm - 122 changes
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 05/10/2008 - 122 changes
Uplink Comparison Range: 05/07/2008 12:14P - 05/07/2008 01:34P
Channel Additions:
574 - FPCHN [MPEG2 SD] added to EchoStar3 61.5W TP 31 ConUS beam (Available)
5796 - HDSKD [MPEG4 HD] added to EchoStar3 61.5W TP 16 ConUS beam (Not Available)
5797 - HDSKD [MPEG4 HD] added to EchoStar3 61.5W TP 16 ConUS beam (Not Available)
5798 - HDSKD [MPEG4 HD] added to EchoStar3 61.5W TP 16 ConUS beam (Not Available)
7664 - KBDF [MPEG2 SD] added to EchoStar10 110W TP 29 Spotbeam 17 (Not Available)
8385 - KUVM [MPEG2 SD] added to EchoStar10 110W TP 12 Spotbeam 16(SE TX) (Not Available)(Dewalt, TX)
8417(26) - KODF [MPEG2 SD] added to EchoStar10 110W TP 29 Spotbeam 21 (Not Available)(Britton, TX)
8417(26) - KODF [MPEG4 SD] added to Echostar12 61.5 TP 01 Area 3 beam (Not Available)(Britton, TX)
9040 - KHDF [MPEG2 SD] added to EchoStar10 110W TP 12 Spotbeam 38(NV) (Not Available)(Las Vegas, NV)
9433 - DISE [MPEG4 HD] added to EchoStar3 61.5W TP 25 ConUS beam (Not Available)
9433 - DISE [MPEG4 HD] added to EchoStar5 129W TP 11 ConUS beam (Not Available)
9434 - ABCFM [MPEG4 HD] added to EchoStar3 61.5W TP 25 ConUS beam (Not Available)
9434 - ABCFM [MPEG4 HD] added to EchoStar5 129W TP 11 ConUS beam (Not Available)
14507 - KHBS2 [EPG] added to EchoStar10 110W TP 23 Spotbeam 20(OK,MO,AR) (Not Available)(Fort Smith, AR)
14508 - KHOG1 [EPG] added to EchoStar10 110W TP 23 Spotbeam 20(OK,MO,AR) (Not Available)(Fayetteville, AR)
14510 - KHOG2 [EPG] added to EchoStar10 110W TP 23 Spotbeam 20(OK,MO,AR) (Not Available)(Fayetteville, AR)
19207 - SPKHT [DATA] added to EchoStar1 148W TP 15 ConUS beam (Not Available)
19208 - LIFAP [DATA] added to EchoStar1 148W TP 15 ConUS beam (Not Available)
Channel Removals:
5455 - MT65 (NA) removed from EchoStar5 129W TP 11 ConUS beam
5456 - MT66 (NA) removed from EchoStar5 129W TP 11 ConUS beam
6801 - UP5 (NA) removed from Echostar12 61.5 TP 11 Area 5 beam
6818 - UP5 (NA) removed from Echostar12 61.5 TP 11 Area 3 beam
6819 - UP5 (NA) removed from Echostar12 61.5 TP 13 Area 3 beam
6820 - UP5 (NA) removed from Echostar12 61.5 TP 15 Area 3 beam
6821 - UP5 (NA) removed from Echostar12 61.5 TP 01 Area 4 beam
6822 - UP5 (NA) removed from Echostar12 61.5 TP 03 Area 4 beam
6823 - UP6 (NA) removed from Echostar12 61.5 TP 05 Area 4 beam
6824 - UP6 (NA) removed from Echostar12 61.5 TP 07 Area 4 beam
6825 - UP6 (NA) removed from Echostar12 61.5 TP 11 Area 4 beam
6826 - UP6 (NA) removed from Echostar12 61.5 TP 13 Area 4 beam
6827 - UP6 (NA) removed from Echostar12 61.5 TP 15 Area 4 beam
6828 - UP6 (NA) removed from Echostar12 61.5 TP 01 Area 5 beam
6829 - UP6 (NA) removed from Echostar12 61.5 TP 03 Area 5 beam
6830 - UP6 (NA) removed from Echostar12 61.5 TP 05 Area 5 beam
6831 - UP7 (NA) removed from Echostar12 61.5 TP 07 Area 5 beam
6832 - UP7 (NA) removed from Echostar12 61.5 TP 09 Area 5 beam
6833 - UP7 (NA) removed from Echostar12 61.5 TP 13 Area 5 beam
6834 - UP7 (NA) removed from Echostar12 61.5 TP 15 Area 5 beam
6835 - UP7 (NA) removed from Echostar12 61.5 TP 01 Area 6 beam
6836 - UP7 (NA) removed from Echostar12 61.5 TP 03 Area 6 beam
6837 - UP7 (NA) removed from Echostar12 61.5 TP 05 Area 6 beam
6838 - UP7 (NA) removed from Echostar12 61.5 TP 07 Area 6 beam
6839 - UP8 (NA) removed from Echostar12 61.5 TP 09 Area 6 beam
6840 - UP8 (NA) removed from Echostar12 61.5 TP 11 Area 6 beam
6841 - UP8 (NA) removed from Echostar12 61.5 TP 13 Area 6 beam
6842 - UP8 (NA) removed from Echostar12 61.5 TP 01 Area 7 beam
6843 - UP8 (NA) removed from Echostar12 61.5 TP 03 Area 7 beam
6844 - UP8 (NA) removed from Echostar12 61.5 TP 05 Area 7 beam
6845 - UP8 (NA) removed from Echostar12 61.5 TP 09 Area 7 beam
6846 - UP8 (NA) removed from Echostar12 61.5 TP 11 Area 7 beam
6847 - UP9 (NA) removed from Echostar12 61.5 TP 13 Area 7 beam
6848 - UP9 (NA) removed from Echostar12 61.5 TP 15 Area 7 beam
6856 - UP10 (NA) removed from Echostar12 61.5 TP 01 Area 9 beam
6857 - UP10 (NA) removed from Echostar12 61.5 TP 03 Area 9 beam
6858 - UP10 (NA) removed from Echostar12 61.5 TP 05 Area 9 beam
6860 - UP10 (NA) removed from Echostar12 61.5 TP 09 Area 9 beam
6861 - UP10 (NA) removed from Echostar12 61.5 TP 11 Area 9 beam
Channel Moves:
6800 - UP4 moved from Echostar12 61.5 TP 09 Area 4 beam to Virtual77w 77W TP 03 ConUS beam (NA)
6802 - UP2 moved from Echostar12 61.5 TP 03 Area 1 beam to Virtual77w 77W TP 05 ConUS beam (NA)
6803 - UP3 moved from Echostar12 61.5 TP 01 Area 2 beam to Virtual77w 77W TP 07 ConUS beam (NA)
6804 - UP7 moved from Echostar12 61.5 TP 15 Area 6 beam to Virtual77w 77W TP 09 ConUS beam (NA)
6805 - UP4 moved from Echostar12 61.5 TP 05 Area 3 beam to Virtual77w 77W TP 11 ConUS beam (NA)
6806 - UP8 moved from Echostar12 61.5 TP 07 Area 7 beam to Virtual77w 77W TP 13 ConUS beam (NA)
6807 - UP10 moved from Echostar12 61.5 TP 13 Area 9 beam to Virtual77w 77W TP 15 ConUS beam (NA)
6809 - UP4 moved from Echostar12 61.5 TP 01 Area 1 beam to Virtual77w 77W TP 17 ConUS beam (NA)
6810 - UP4 moved from Echostar12 61.5 TP 03 Area 2 beam to Virtual77w 77W TP 19 ConUS beam (NA)
6811 - UP4 moved from Echostar12 61.5 TP 07 Area 2 beam to Virtual77w 77W TP 21 ConUS beam (NA)
6813 - UP4 moved from Echostar12 61.5 TP 15 Area 2 beam to Virtual77w 77W TP 23 ConUS beam (NA)
6814 - UP4 moved from Echostar12 61.5 TP 01 Area 3 beam to Virtual77w 77W TP 25 ConUS beam (NA)
6815 - UP5 moved from Echostar12 61.5 TP 03 Area 3 beam to Virtual77w 77W TP 27 ConUS beam (NA)
6816 - UP5 moved from Echostar12 61.5 TP 07 Area 3 beam to Virtual77w 77W TP 29 ConUS beam (NA)
6817 - UP5 moved from Echostar12 61.5 TP 09 Area 3 beam to Virtual77w 77W TP 31 ConUS beam (NA)
7041 - WJET moved from EchoStar9 121W TP 14 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)(Erie, PA)
7047 - WQLN moved from EchoStar9 121W TP 14 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)(Erie, PA)
7195 - KSIN moved from AMC-15 105W TP 23 ConUS beam to AMC-15 105W TP 02 ConUS beam (A)(Sioux City, IA)
7196 - KXNE moved from AMC-15 105W TP 23 ConUS beam to AMC-15 105W TP 02 ConUS beam (A)(Norfolk, NE)
7210 - WAOW moved from EchoStar9 121W TP 09 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)(Wausau, WI)
7216 - WHRM moved from EchoStar9 121W TP 09 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)(Wausau, WI)
7319 - WQCW moved from AMC-15 105W TP 18 ConUS beam to AMC-15 105W TP 02 ConUS beam (A)(Portsmouth, OH)
7321 - WPBY moved from AMC-15 105W TP 18 ConUS beam to AMC-15 105W TP 02 ConUS beam (A)(Huntington, WV)
7325 - WPBO moved from AMC-15 105W TP 18 ConUS beam to AMC-15 105W TP 02 ConUS beam (A)(Portsmouth, OH)
7770 - WLNE moved from EchoStar9 121W TP 14 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)(New Bedford, MA)
7775 - WLWC moved from EchoStar9 121W TP 14 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)(New Bedford, MA)
7776 - WSBE moved from EchoStar9 121W TP 14 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)(Providence, RI)
7860 - KSWO moved from EchoStar9 121W TP 09 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)(Lawton, OK)
7929 - WVAW moved from AMC-15 105W TP 07 ConUS beam to AMC-15 105W TP 02 ConUS beam (A)
7933 - WHTJ moved from AMC-15 105W TP 07 ConUS beam to AMC-15 105W TP 02 ConUS beam (A)(Charlottesville, VA)
14295 - WPRI2 moved from EchoStar3 61.5W TP 16 ConUS beam to Echostar12 61.5 TP 11 Area 6 beam (NA)(Providence, RI)
14589 - WNAC2 moved from EchoStar3 61.5W TP 16 ConUS beam to Echostar12 61.5 TP 11 Area 6 beam (NA)(Providence, RI)
14844 - WJAR2 moved from EchoStar3 61.5W TP 16 ConUS beam to Echostar12 61.5 TP 11 Area 6 beam (NA)(Providence, RI)
15126 - WPRI3 moved from EchoStar3 61.5W TP 16 ConUS beam to Echostar12 61.5 TP 11 Area 6 beam (NA)(Providence, RI)
15243 - WLNE2 moved from EchoStar3 61.5W TP 16 ConUS beam to Echostar12 61.5 TP 11 Area 6 beam (NA)(New Bedford, MA)
15244 - WSBE2 moved from EchoStar3 61.5W TP 16 ConUS beam to Echostar12 61.5 TP 11 Area 6 beam (NA)(Providence, RI)
Channel Package Flag Changes:
108 - LIFE [MPEG2 SD] - EchoStar1 148W TP 15 ConUS beam changed to Available
108 - LIFE [MPEG2 SD] - EchoStar7 119W TP 13 ConUS beam changed to Available
464 - SPORT [MPEG2 SD] - EchoStar8 110W TP 02 ConUS beam changed to Available
713 - VIVA - Anik F3 118.7W TP 01 ConUS beam changed channel package flags
714 - NBN4 - Anik F3 118.7W TP 01 ConUS beam changed channel package flags
719 - STARC - Anik F3 118.7W TP 07 ConUS beam changed channel package flags
721 - STARM - Anik F3 118.7W TP 07 ConUS beam changed channel package flags
729 - CHNLV - Anik F3 118.7W TP 07 ConUS beam changed channel package flags
773 - IQRAA - Anik F3 118.7W TP 22 ConUS beam changed channel package flags
782 - IQRAA - EchoStar1 148W TP 09 ConUS beam changed channel package flags
782 - IQRAA - EchoStar3 61.5W TP 08 ConUS beam changed channel package flags
903 - AAGTV - Anik F3 118.7W TP 07 ConUS beam changed channel package flags
903 - AAGTV - EchoStar3 61.5W TP 31 ConUS beam changed channel package flags
Channel Renames:
9463 - TEMP renamed to TOON (NA)
9475 - WORLD renamed to VMOV (A)
9484 - TEMP renamed to TDIS (NA)
9492 - TEMP renamed to BRAVO (NA)
9494 - TEMP renamed to ESNWS (NA)
Transponder Changes:
EchoStar3 61.5W TP 16 ConUS beam changed FEC from 5/6 to 2/3
EchoStar3 61.5W TP 16 ConUS beam changed modulation scheme from QPSK to 8PSK
EchoStar3 61.5W TP 16 ConUS beam changed symbol rate from 20000 MSPS to 21500 MSPS
Virtual77w 77W TP 01 ConUS beam changed FEC from 2/3 to 5/6
Virtual77w 77W TP 01 ConUS beam changed modulation scheme from 8PSK to QPSK
Virtual77w 77W TP 01 ConUS beam changed symbol rate from 21500 MSPS to 20000 MSPS
Channels in the system: 3773
(A) = Available to subscribers
(NA) = Not Available
looks like the temp channels are hd also
renamed to good stuff.
So if they follow suit to how USAHD and SciFiHD were handled, we could get these channels anywhere from Friday to November!
Two of those new HD channels are supposed to be turned on to customers by the end of the week.
The others should be available by the end of next week. :)
(Of course that is just a rumor) ;)
So it looks like 6 National HD channels up and testing, but nothing made available today, am I correct?
Well thats a good sign but the big question is now when will they go live... Oh nevermind two this week then two next week.. :)
hey scott or digi,so is the change of prog.on world to the new voom movies channel or is it onlya name change?
Uplink Activity 5/01/08 2:00 AM EDT -- 3 minor moves
Uplink Activity 5-07-08 4:45PM EDT 2 changes
