Dishpointer Pro "not licensed"
Diansul
52
5
Texas
I've used Dishpointer Pro for years to find a hole in the trees that allows me to get DirecTV on my dish at an RV site. But now, Dishpointer Pro shows "not licensed" on my Android phone, and the app is no
longer available on Google Play. I really just need the app for AR display of the satellites to find the hole in the trees. I don't mind paying for an app, but not the $14.95 a week that some of the
dish finder apps are charging.
Any suggestions as to a reliable app for this purpose?
The Winegard Signal Finder app does both satellite and OTA locations. The satellite function includes an AR display similar to DishPointer Pro. I used both with equal results during my fulltiming days until we went all streaming. Oh, and the app is free!
Thanks for posting about the Winegard app; it looks excellent. But, google play for android says it's not available for for my android phone.
  • Sad
Reactions: NYDutch
As long as DishPointer is still working, I'd keep on using it. About the only thing that changes are the satellite listings from time to time. The current Dish and Directv locations rarely change, so that shouldn't be a problem. The current locations have been the same for years, and when 77 and 129 were dropped, it was a simple matter to deselect them in the satellite listings so they no longer showed in the AR view.
how old is your phone/what version of android is it running? Could that be why Dishpointer doesn't show up in the app store anymore in addition to Winegard not installing?
The Android Dishpointer Pro app has been obsolete for years. It was built for a much older version of Android at that time. It's not supported anymore, so it won't run on newer Android, and you can't contact the owner.
However, you CAN use the online version with your laptop: DishPointer - Align your satellite dish
Reactions: NYDutch and FTA4PA
Thanks for the info, Mike. I run DishPointer on an older spare phone, so I wasn't aware of the Android version issue.
Reactions: primestar31
Yeah, the deal is that the Dishpointer Pro app is not working on my android (ver 14) phone. I do use the Dishpointer.com site to get coordinates and elevations, however. The reason I'm looking for a replacement phone app is that we often camp in heavily treed areas; an "AR" view of the locations of the necessary satellites superimposed on the sky helps me find a hole in the foliage to get a signal.
The Winegard app works ok on my Samsung A51 with version 13, so I wonder what they changed in 14 that Winegard hasn't caught up with.
It'll still run on your old phone, IF you still have it, and if it hasn't had the latest Android update.
You should be able to download an APK of Dish Pointer PRO online and install it on your Android device that way.
Diansul It won't run on new Android, it clearly says that if you try to bring it up. As I said above, it WILL run just fine on his old phone, if he still has it. It doesn't need active phone service to work. It works on my older Motorola Moto G6, it doesn't run on my newer Motorola Moto G Power 5g though with Android 14. Downloading the APK wouldn't help, even on an old phone because it wouldn't have a license at all, and you can't buy one anymore. It was a paid app.
Reactions: NYDutch
Unfortunately I have a new phone because my old phone is a dead, dead, dead. If anyone learns about a good AR satellite finder, I'd really appreciate a posting. My old Suunto Tandem works, sort of, so I'll just use it for now. Thanks for all the ideas.
See if this will work. Maybe it's the newest version of Dishpointer? It has a paid "Pro" version. It says it would work with my latest phone, that has Android 14: DishPointer (Satellite Finder - Apps on Google Play
I'm in the same situation or worse. I uninstalled the APP from the old phone as per instructions from memory in preparation to installing the APP on my new Galaxy S25+. On searching on Google play, I discovered that the APP was no longer there and Dishpointer.com doesn't have the APK files anymore. I found version 1.1 on Aptoid, but it's no compatible with Android 15. What version APK do you have and what was the latest version out there?
PIP not showing ON Option
DIRECTV Transponder Map ~ Data 7/23/2025
