DP 625 INSTALL TO 2 lNBF
aala4748
tennessee
I receive 110 on one side and 119 on the other side . This is a dual receiver. How do i get both at the same time. The dish is a Dish 500 with 2 lnbs 110 & 119. THANKS
As I said, that's not enough information. That could be a DishPro Twin, A DishPro Plus Twin, or a Dish Quad LNB for all you've said. Each of those models has slightly different wiring requirements.
Look at the sticker on the LNB I linked. Does yours have the same sticker? If that's the sticker you have, then it only takes one cable and a separator. If yours doesn't have the same sticker, buy one that has the right sticker; it makes life easier.
Cowboy I think he means he has 2 single LNBs on his dish seeing he says there is a space between them. Most likely they are LEGACY and probably singles rather than duals. Best in that case is replace with a Dish Pro Plus TWIN.
LEGACY single or dual have plain grey plastic.
Dish Pro single or duals have black DP logos on the back of the LNB and could be easily connected to a DP34 switch.
More info on NFL RedZone on Dish
3rd 622 in a few months!
