DSL Service and DISH
magoo30
Aug 12, 2007
midwest
Am new to DISH,am wondering if my DSL service thru my telephone provider/Verizon will work with the new DISH system I am having installed tomorrow ?
TNGTony
Unashamed Bengal Fan
Sep 7, 2003
10,041
803
Cincinnati, Ohio, USA
Welcome to Satelliteguys
I'm not sure what you mean "work with". If you are asking, can Dish Network's boxes use the DSL phone line to phone home: yes. I have a DSL-only phone line and my 622 has no troubles phoning home via land line.
If you are asking can you network the 622 so that it can phone home via the internet connection: theoretically yes you can. I haven't tried it myself but it's supposed to work. :)
Did you mean something else? Let us know!
See ya
Tony
magoo30
Aug 12, 2007
midwest
Thanks alot,you answered my question on the first sentence of your reply. I was asking if the DISH network could phone home thru my DSL phone service.
tnsprin
1,601
To clarify a bit. Many DSL phone services work with Dish receivers, but not all. Sometimes you also need to enable a prefix to your calls to enable modem support.
For ViP622/722 they are just rolling out software enabling Ethernet support which will give you several new options, Supposively it can also be used instead of hooking up your phone line.
Cegarrett
800
Shreveport, LA
You are saying DSL Phone Service.
Do you mean Land line that handles your DSL Service if that's what you're referring to then yes it will work as long as you have a DSL Filter between the 622 and the wall.
Do you mean Phone Through your DSL (VOIP) some VOIP providers work and some don't
Do you mean using your DSL Internet to "Phone home" through the Ethernet port It Should work as the 622 will just be another "Network Connection" on your Network.
Hope this Helps,
cegarrett
lowdown
62
I am also new to Dish Network and have DSL service. I am wondering the same question.
I have a 722 and a 222 connected straight to the phone line.
Should I be using a DSL filter like I have to for each regular telephone on each of the receivers?
lowdown
62
Thank you for the information. :up
Cheap DSL filters have been ordered.
How often do the boxes dial in? Is it based on number of PPV events ordered or is it a set schedule?
Barry Erick
1,020
Dallas
Filters is it. Some DSL's run a seperate line from your phone network connector and the filter is in that box, making the line running to all phones filtered in one spot. This is the old way, and the way usually used IF the phone company is your DLS company and does the install. In most other places, there is no seperate line and every place you put a phone, you need a filter. None where the DSL modem is plugged in.
I'm lucky, my phone company's main switch is about 1/2 mile away and they offer DSL. I've had it for several years with no problem.
what would you like your DVR to do?
trying to verify wiring of dish pro 1000
