Equipment required for additional receiver
ndcart
SatelliteGuys Guru
130
TX
Third topic of the day, here goes. I have a Dish 500 system with a 522 receiver. It has two SW 21 swictes on it out of the dish. I would like to add a third receiver for another room, but am not sure what equipment other than the additional receiver that I would need. Any help would be appreciated. Thanks!
You could go with a Quad Lnb that can feed up to 4 tuners (2 for the 522 and one for the third receiver). Or you can get a DPP Twin, with the DPP Twin you can have a single run to the 522 using a separator and another run to the third receiver.
I would go with the DPP Twin.
Are you sure those switches are SW21s? Since you have a 522, most likely you have DP21s. Do you have a second dish?
Thanks for the info. I do not have a second dish, and just double checked the switches. They are SW21s. I'm fixing to look up that part on the DishStore. Thanks again!
Here you go:
http://www.dishstore.net/product_info.php?cPath=40&products_id=229
So you have legacy dual lnbs. Like I said, just upgrade your lnb to Dish Pro Plus and you should be set. One more thing, make sure that the cable you have is RG6 and rated to 2200Mhz it should say in the outside of the cable.
why no mirror fee?
Hd
