Find HD Movies Using Dish Remote Access
blanquitoman1984
268
Fontana, CA
With all the Starz Channels I would like to get rid of the movies that I have with commercials and replace them with the movies from Starz. I could set the recordings manually, but I think its much faster using the web. Only problem is that I choose movies (Filter), Later, and Hd content only, all I get is movies from the Hallmark Channel (25 entries).If I click on (Hd channels only) it say's, there where no results found in Movies on Later. If I uncheck all I could set recordings, but only in Sd not Hd.
Any suggestions other then doing it manually?
If you go into you recordings menu and highlight one of them then hit the search button it will find them if they are on a starz channel. Then set a new timer. That is what I would do
