good signal,poor reception on g-3
hanson
32
ky.
on galaxy 3 at 95 degrees,ive got 80 % signal quality,but almost no picture at all. using a fortec star ultra reciever and 10 ft. dish
try bumping ( slightly moving the dish east or west with the motor) when it comes to signal , Quality is what your looking for. pick a known live transponder on that sat and move the dish slightly see if it improves :)
tried moving it,getting good signal quality,but the picture starts messing up and no signal comes up on screen
i have a 10ft. mesh dish,fortec ultra,california lnb,no switches,and the dish is 25-30 ft. away from the house if that makes any difference.
Are you slaving the Ultra to an analog receiver, or direct connect to LNB?
If slaving, are you using a DC-block or "T" with 1 power pass leg?
If not slaving, since you have a Californina Amp LNB, I assume you have a polarotor and must be controlling polarity via an analog receiver.... if so, I would recommend telling your Ultra that all transponders are horizontal, because some LNBs don't work well at 13V that the Ultra will be putting out when set on vertical.
I have the same problem....95W C Band
both TPs 70% quality
4040 H 1110 ---->Black
4167 V 0983 ---->Image very good
BSC621-2 conected direct to Pansat 2500a
Thanks in advance......
If you are trying to get the equity mux on G3, you may have to tune your dish a little. The tight FEC requires a high carrier to noise ratio.
I had to give my 10' elevation a couple turns and it locked right on.
My dish has little room for error on that mux.
FREE 10 Foot Find! Possible BirdVeiw Find?
PVC Schedule 40
