H20 direct channel entry problem
dervari
198
Atlanta, GA
Ok...I have a ReplayTV and would like to use the HD feed to record from. However, I have two sets of locals. For example, the first 5 is AT5 and the second is WAGA. When I select a channel via the keyboard, it defaults to the normal SD broadcast channel (AT5). Hitting CH UP will bring be to the HD channel (WAGA). Is there any way to "get rid" of the SD channels so that just entering a channel number will take me to the HD feed instead of the SD?
Thanks!
Try blocking out the channel you don't want. I am not sure about on the H-20 but I know it works on some of the older receivers. Blocking out a channel is on page 61 of the H-20 on-line manual.
