hd channels on sd receiver
  • WELCOME TO THE NEW SERVER!
dalebrow
20
cincinnati
Hello, just got dtv with a hd receiver in the family room and sd in the bedroom. I get all channels in the bedroom except hdnet and hd theater. These are hd channels but I get all other hd channels,in sd of course. What could be the problem, thanks. Aren't all hd channels supposed to be able to be watched on the sd receiver?
SD recievers are NOT HD compatiable. you will need a HD reciever.
SD reciever only shows SD and no HD channels
HD reciever will show SD and HD channels.
SD means Standard Digitial
HD means High Definition.
SD will not broad cast High Def channels. you may THINK youre getting HD on SD but youre not.
what model are your recievers?
H20? D12?
The correct answer is that there is no sd version of the two channels you mentioned. That's why you can't get them on the sd receiver.
If he livesin a 72.5 market, he could have gotten a HD receiver in place of a sd receiver. Not sure if that Is the case here.
So what you are saying is that all the other channels are broadcast in both hd and sd,right? I thought that they were just down converted to 480i, but I guess not. Thanks for the answers.
I believe the channels your referring to are in the HD Extra package, which your getting apparently, that package consist of channels ONLY made in HD, so as mentioned above, there are No SD equivalent channel for you to watch.
There are not too many that are HD only, but those are a few of them.
HDNet(306,79) and HDTheater(281,76) are not in the HD Extra package. You get them with Choice or above packages as long as you have HD Access($10/month) on your account and an HD receiver...
You are right, but the real point of the thread is that hd only channels, like the two you mentioned, can't be received on sd equipment.
I could pick them up with dish in the bedroom and it was sd,was it maybe because of the dual tuner down converting them?
I suspect that you had an R22. The R22 was marketed as an SD DVR, but it can actually handle HD channels and display them appropriately on either an SDTV or an HDTV.
This is the danger of being mysterious about what receivers you have.
Yes, with a Dish Duo HD Receiver, TV 1 is HD and TV 2 has downcoverted HD. With D*, as far as I know, there are no receivers like that, yet. If you want the HD channels in the other room, you would need an HD receiver instead of an SD receiver with D*.
What I have is a d12-500 in the bedroom and a h23-600 for hd in the tv room. With dish is was a vip222k dual tuner, and like I said it would allow the two channels to be watched in the bedroom, and tv 2 was sd. Tv 2 is what the second tuner was called on the dual receiver.I guess what I said earlier that having both tuners in the same rec. that it just down converted it, i recon?
Yes. We switched from D* to E*. We now have VIP 222ks, and that is how it works in terms of TV2 being able to view the HD channels (in terms of the HD channels being downcoverted on TV2). A relative has HD with D*, and she can only watch HD on the one HD receiver that she has, not on the SD receivers.
