HD upgrade
bill714
Mass
Hi all, I have an all sd system and last year got a Sony 32 HD TV the picture on it suck :(but because I was unemployed I put up with it. Well times are better now and I called for an upgrade I got a HD dvr and install free! I hope the pq will be better!
What I'm wondering is will they install a SWM? If not what dish set up will I get? I have 3 sd receivers will be keeping 2. We have a lot of snow on the ground should I clear the snow out under the dish so the guy can set up his ladder and get to the dish? Anything else I can do to make the install go easy?
If all goes well should I give the guy a tip? He be here tomorrow the 5 so I let you know how it goes. Wish me luck!:D
If you have three SD receivers then unless they are all D12s you won't get SWM (and even then probably won't) because only the D12 is SWM-compatible. You will get a Slimline 3 or 5 with a WB68 multiswitch.
Thanks texasbrit yes looks like i will not be getting swm the sd receivers I have are D11-300:(
Spanish HD programming
So how best to order dtv?
