Help! Adding another TV
jas3443
13
Streetsboro, OH
I am finishing my basement and will be adding another TV. My primary TV is on a VIP 612 w/HD and DVR. Is there a box I can upgrade to that will make that work with 2 tv's?
Thanks in advance!
The 622/722/722k receivers all drive two TVs independently, one HD set and one SD set. If you need independent HD on both sets, you'll need another HD receiver.
Otherwise, you can run component to one TV and HDMI to the other and have HD to both sets, although both will show identical programming. There are other methods to split identical HD output to a second set, including HDMI splitting and HD over Cat 5.
How do you run HD over CAT 5?
Adding an OTA antenna to a 722k
No OTA on second tuner?
