Help LNBF STARCHOICE 75E ONLY WITH DIRECT 36X22 OVAL DISH
$0.00
$400.00
tylerlee
11
dear helper
i on using the starchoice lnbf 75e only with the 36x22 worldDirect TV oval Dish..
i would like to setup with 101 and 97w. amc4 and ia5.....
Can it be possible...... if so these are my set up:
Set your receiver to:
101w with Sat B
AMC4
LNB type: Standard
LO freq. 10.750
22KHz – ON…………ok
LNB Power - ON
TP - 11822 (to find the satellite)
IA5 97w with Sat A
LNB type: Standard
LO freq. 10.750
22KHz – Of….ok
LNB Power - ON
TP - 12177 (to find the satellite)
Can you tell me about the skew?? think 116. with this 36x22 dirct tv oval dish....but i can't get any signal......
The Starchoice LNB will only work correctly with a 75e dish. When you work with a "combo" LNB as the SC LNB is, if the focal distance from the dish to the end of the arm isnt the same, it won't work. I tried it with another dual LNB type setup on the wrong dish and all it gave me was a headache
If you want both 101 & 97, I would recommend to get a couple LNB's that will work with most KU band dishes.
will it work with 75eLnbf and 1ForTec Ku-band Lnb with 36x22 oval dish?
thanks Mr. ice....berg
Can these setup be possible with 75e and 97w and the ForTec Ku band single lnb(universal)..????
With 101w.Amc4??
WHAT TYPE OF LNB DO I NEED FOR 101W AMC4. ?????????
AMC4 IS IT KU-BAND LNBF???
thanks again
or you could use Universal LNB's and a 2x1 Diseqc switch
16.0 East / Eutelsat W2
help in iraq?
