Hybrid Dish setup
TVHabit
65
17
Southwest Desert
Picked up a sweet directv dish, mount, twin lnbs and a short cable.
Has anyone converted one to FTA? A Frankenstein of sorts...
Yes, many have hacked a DirecTV or Dish Network dish before. Quite undersized, but would receive the 97w KU stations with an LNBF swap. Make a template to set the LNBF face angle and distance from the reflector. Remove the current circular polarity LNBFs and make a bracket to hold the replacement linear LNBF in the correct centered position. Remember to set the polarity skew.
Reactions: TVHabit and FTA4PA
would probably also work well for NHK on 101W and possibly for PBS on 99W. I used one for a while on 30W. Just keep in mind that because it's undersized for those satellites, it might work fine in clear weather but won't have much margin to account for signal degradation during rain/snow
Reactions: TVHabit
If you can find one, the Shaw / Star Choice 75e ellipticals are great for use on 97, 99, and 101W. They are really just rebranded ChannelMaster 75 cm reflectors and use linear LNBFs by default out of the box.
Everyone else's mileage may vary.
Reactions: TVHabit
I have read that some have converted this type dish but after giving it a good look, it's the lnb conversion that is the bottleneck. Does anyone have a picture of their attempt to configure the lnb? I watched a video on youtube from the save it for parts guy and he used duct tape! Guess it worked but I'm thinking something a bit more permanent!
Thanks to all for your interest and replies...
Many of us have used a universal LNBF mount (or get creative with L brackets and plumbers tape - perforated metal strapping). Use a few inches of aluminum tube (or a piece of 1x2" lumber) to extend the support arm (replacing the plastic mount used by DirecTV and Dish) to place the LNBF throat opening at the correct distance from the reflector, the correct height and at the correct angle. Nothing magical... simply place the new linear LNBF in the center at the same distance, height and angle as the current combo.
www.amazon.com/Universal-Single-Bracket-Holder-FTA-US/dp/B074L85WK2
To add: 101W Ku seems to be (one of if not the) strongest for me, and if I only had Ku I definitely want 101W for the music mux, it's robust FEC and strong signal help a lot. I've thought about using a used Dish/DirectTV dish at my Dads to supplement his OTA (mainly for my benefit when I visit :) )
Reactions: TVHabit
I used a 60cm Shaw Satellie dish (60e) with its original dual-LNB. It worked fine for 101W/97W or 99W/103W at that time when weather was fine. But the fade margin was small so rainy weather killed reception or almost so. But it was all free since they're so plentiful so I couldn't complain.
Reactions: TVHabit
Memories
NEED SUGGESTIONS FOR NEW FTA BOX
