Help with elevation
sleeper
79
Twin Cities MN
My offset dish has 24 degree offset, I need to be at 38, if I put my angle meter on the bottom of the dish and set it at 14 degrees will that work?
If you don't trust the elevation scale on the back of the dish, place a straight edge across the vertical edges of the dish then tilt the dish back 14 degrees (38 degrees - 24 degree offset = 14 degrees).
You will have to make slight elevation adjustments to locate or fine tune the satellite signal.
Multi switch question
TELE satellite 0911 PDF
