Hopper Conection Without Joey
Rifleman62
29
AZ and WA
I wish to connect a Hopper without a Joey until I can instal the cable to the back room for the Joey. Is this as easy as disconnecting a 722, and attaching the same coax to the Hopper without going through a Node?
Or run the standard two coax into the Node and one out to the Hopper?
Two DPP feeds into the node, Hopper on HOST port, 75-ohm terminator on CLIENT port (assuming you will be using a Solo Node.)
Also the coax and barrel connectors both have to be rated for 3GHz. If it's lower than that it may appear work but you will likely have problems with the 2nd and/or 3rd tuners.
MX-780 remote and hopper (please help)
