That's what I have, 3 Velop Tri-Band Mesh routers, all wired to a switch at the Modem by cat 5 I ran to each locationI have 6 Netgear Access Points, all wired ( Wall Fished) throughout my House, no matter what room I am in, I get 600-800 down.
A lot cheaper then Orbi, their most expensive is $1499 on Amazon and you only get 3 of them.
My Access Points are $90 each, so 6 is $540.
Welcome to LWC Communities!
www.netgear.com
I always like Netgear! ISP always seem to hate them. They want their rental feesI have 6 Netgear Access Points, all wired ( Wall Fished) throughout my House, no matter what room I am in, I get 600-800 down.
www.netgear.com
I suspect this is because ISPs don't want to be in the position of providing primary support for Netgear routers.I always like Netgear! ISP always seem to hate them.
The only danger comes from having multiple DHCP servers as this will allow devices to reside on different subnets. Using the Quantum should be just fine as long as there are no other devices acting as routers.Is it even possible or practical to leave the DHCP handling on the Quantum, and just use 2-3 mesh devices? I plan to hard wire each device.
Opposed to which solution?TKS. But OBE now. SWMBO is opposed.
Moneybags!Besides, 7 comes out next year.
It may well be over-provisioning as turned out the be the case with Cat7 or Cat8 cabling. If the cost of connecting a device costs more than the device itself, what's the point?Moneybags!
If you're waiting for the second coming of Nikola, you will likely be profoundly disappointed.For when all entertainment and household power is sent directly to us over the air
Not sure I would call 9.6 Gb/s meager.It may well be over-provisioning as turned out the be the case with Cat7 or Cat8 cabling. If the cost of connecting a device costs more than the device itself, what's the point?
Unless the broadcasts reach further or are more resiliant, what's the point?
Wi-Fi 7 brings only ludicrous speed (46Gbps) over Wi-Fi 6's relatively meager 9.6Gbps from what I can gather. Wi-Fi 6's big deal was that it added radio bands to the Wi-Fi 5 mix. Most of these advances haven't improved the reach of Wi-Fi and in practice, have made it worse.
What group of wireless devices could possibly need (or process) 46Gbps of data?
It may well be is if you're all in for everything being Wi-Fi.Not sure I would call 9.6 Gb/s meager.
Very little in my house runs on WiFi other than the smart lights and my kids' Firesticks, phones and tablets. All the big stuff, TV's, Computer, AVS, my Nvidia Shield Pro, etc are all hard-wired via switches and Tri-band Mesh routers to a 1Gb/s Fiber Optic modem. WiFi is too inherently weak as it is over short distancesIt may well be is if you're all in for everything being Wi-Fi.
Remember that Wi-Fi is a pathway (or a small number of pathways in the case of MIMO) shared between all its connected devices and each pathway is half duplex.
