How many Dishes for South Asian Programming + America 120
akshay_bombay
Oct 9, 2011
7
PA
This is Odd , and i need some help from guys ..
Few Months ago (may be a year ) i used to get South Asian Programming as well as America 120 , with just 1 single dish.
I then stopped subscribing to the international programming. Now when i started my subscription again , i am being told i need 2 dishes for these channels . In fact the first time also i was told the same by the dish tech at home , but some sharp guy at the Dish Tech Support , told my tech that it was possible to get these channels with just 1 dish .
Can someone put some light on this ...
I am in Pennsylvania.
the mack
1,479
483
HOCKEYTOWN
depends weather your locals are on the eastern or western arc....more than likely you have a eastern arc dish now and that is why you would need two dishes....if you are on the western arc you can get by with one dish (1000plus)
boba
11,350
1,036
Dorchester, TX.
The international channels were formerly broadcast on 61.5 and 118.7. Now they are only on 118.7 which suggests you are on the Eastern Arc seeing the 61.5 satellite is part of EA. If you had continued subscribing to the international channels DISH would have moved you free of charge to the 118.7 satellite. Now DISH will have to determine if you still get a free move to 118.7.
If your locals are on both East and West Arcs you can still get away with only one dish. In PA you are probably Eastern Arc only so you would need a big dish aimed at 118.7 I think the DISH 500+ is a 36" dish the largest DISH normally uses.
akshay_bombay
Oct 9, 2011
7
PA
Right now i have a 1000.4 dish with 77,72 and 61.5 satellite orbitals .
They say i need 118.7 , and need another dish for it ...
I was thinking of replacing 61.5 with 118.7 , if possible ?? They say Dish 500+ would not work in eastern arc. for quad lnbs ..
akshay_bombay
Oct 9, 2011
7
PA
I called Dish again, they said all i need is a wing dish for 118.7 .. Do you guys thing , that this would work?
CK SatGuy
Formerly ckhalil18
Feb 7, 2011
4,023
112
The Motor City
So is a wing dish , a totally separate dish ??
Yup. Pretty much if you live on the east coast now, you now need 2 dishes if you want HD and international programming. As Boba said earlier, they used to have internationals on 61.5 where you would only need one Dish, but they pulled those because supposedly, they wanted to add more HD channels in the future.
nismoman
Mar 5, 2011
33
md
If you don't care about HD you can use one dish for 110, 119, 118.7. You'll get all the programming but no HD
Hopper Timers not visible online or via iOS App
Defective power supply! How can I rescue my recorded shows?
