hr-20-700 temp guage
kopper
10
looks like they put a temp readout in the second screen of setup screen my reads125 degrees
They also have a temp guage in the R15
the temperature reading is from the Hard Drive
ebonovic,
Is this temp normal ?
My internal temp is also 125*
Am I correct saying that the most recient update for the HR20 is Oxcc ???
Jimbo
The most recent update is 0xCC (rolled out yesterday, and all units should have it by now)
Upper 120's is the normal range for the unit.
Both of mine sit at 127
The internal temp on my HR20 was reading 115° yesterday evening, but I had a fan on behind it. :)
Thanks,
Jimbo
does this thing have a fan in it? man does the top of that case get hot. you can boil an egg...
A little trick. I use a notebook cooler pad, $20 at Walmart, from Targus. Just plug it into the USB port, and it sits under the unit and sucks the heat out the back. Keeps the top from getting hot. It definitely works.
