HR2x / R22 CE Release for 10/17 0x0290
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,031
436
Central Michigan
Systems in CE:15:13
HR20-100 • HR20-700
HR21-100 • HR21-200 • HR21-700 • HR21Pro
HR22-100 • HR22-200
R22-100 • R22-200
Window of opportunity to download:
Friday, October 17, 2008 11:00PM - 2:30AM ET
Saturday, October 18, 2008 11:00PM - 2:30AM ET
PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the CE Chat on Friday nights:
cechat.satelliteguys.us
The Contents of this CE Download:
Differences based on last National Release
  • Items from CE:15:01 through CE:15:11
  • Items from CE:15:12 - Moderate Risk/Customer Candidate
  • Items from CE:15:13 Customer Candidate
Improved
  • Under the hood improvements
  • Recording tip display from the prioritizer
  • Closed Captioning improvements
  • Improvements to guided setup
  • Improved uPNP compatibility
  • Improved Guide scrolling speed and channel banner surfing speed
  • Improved consistency in Advanced Program Guide
  • XM Programs from XM Channels are no longer auto-recorded
  • Stability in Playlist when disk space is low
  • Stability in Mediashare
  • Stability in favorites list after reboot
  • Stability when coming out of standby
  • Stability when exiting signal meter screen
  • Stability in interactive TV iTV applications
  • Stability when watching a program that is currently downloading On Demand
  • Recording tips can now be disabled on all models including R22
  • TV Aspect Ratio can now be set on all models including R22
  • 12 - Softpad reliability
  • 12 - MediaShare stability and reliability
  • 12 - Improved trickplay behavior on HR21/AM21 OTA channels
  • 13 - Remote Booking - now uses recording defaults
  • 13 - softpad
Updated
  • Added HD Icon to DIRECTV on Demand Queue
  • Added 1080p Icon to DIRECTV on Demand listings where applicable
  • Prioritizer Screen now shows the channel for every Series Link
  • More Actors per program in Info Screen
  • Audio Options now removed from TV Options if program has only one audio channel
  • New Factory Default is to Hide SD Duplicates
    HR20/HR21/HR22 only
  • Recent Searches
  • Remote Code text for AV1/AV2
  • More Info in Resolution Screen
  • Record Icon is now removed when stopping recording from grid guide
  • Picture-in-Graphics is now consistent on the DIRECTV On Demand homepage compared to the Guide.
  • Record Icon now appears in channel banner
  • 12 - "About to record" OSD
  • 12 - Screen Saver
  • 12 - Gray screen issue
  • 13 - Wireless setup screen
  • 13 - Skip-to-tick: operation in Live TV
  • 13 - Skip-to-tick: trickplay bar display in Live TV
  • 13 - Skip-to-tick: flashing trickplay icon
New features
  • Support for Tversity Internet Radio
  • Toggle between two recordings with the {PREV} button
  • Song Title on screen-saver XM Channels
  • Channels not subscribed are different color in grid
  • Miscellaneous Options Menu under Parental, Fav's, and Setup
  • Support for Cisco Wireless Bridge Linksys WGA600N
  • POST Power on Self-Test
  • Super Skip to Tick
  • 1080p/24 support
    HR20/HR21/HR22 only
  • Auto Extension/Soft Padding
  • 12 - Fall Welcome Screen
Notes
  • 12 - Download may be delayed on Friday download .. be patient
  • 12 - Guide cache will be flushed .. guide & todo list will rebuild over next 24-48 hours
  • 13 - Fortunes are not enabled in this release
Important Notice
  • Reverting back to National will delete all recordings made with this version of code.
  • When reporting issues with 1080p, please include the TV resolution information reported from the Miscellaneous Options screen as well as your TV make & model.
this ce so far is better than the last two. the last two updates slowed the response time to commands almost immediately all the way to the next update. x290 was already faster right after downloading than the previous two even though the 1st 24hrs after an update is the worst because of all the info being downloaded to the drive. channel changing also improved. :)
Anyone notice that the HR20-700 seems to take longer when your doing the download, as far as when you initially hit the check mark and wait for it to shut down and power back up.
It seems like when trying to shut down, it is taking forever the last few times, making me hope that the unit is not getting old and harder on the unit itself.
It always does come back up, but seems like it would rather go to sleep :)
Only problem I've seen so far is that my Caller Id is no longer working, everything else is working as normal.
Jimbo
Planning on hitting the Saturday download window.... what's the Wireless Setup screen for? I mean, these dvr's don't have built-in wireless, so what's the point?
You can plug in a USB wireless adapter. Check for compatible adapters first if you need to go that route.
But if you add the Cisco Wireless Bridge Linksys WGA600N the box will allow you to configure it directly via the menus vs. having to connect it to a PC first and run the configu program there.
NETWORK SERVICES ISSUE!!
Network Connects fine sending reports and VOD works fine except channel 1080. But Network Services fails and always has. I even bought a new router, because I thought it was a problems with my old one, so I bought a new NETGEAR WNR2000 Wireless N Router. I have it set up as DHCP but Reserve a certain IP for my R22-100. I set up port forwarding and it fails I tried DMZ and nothing, I also disabled the firewall on it. It still doesn't work. I am contacted Negear Technical Support to see if it is a problem with my unit and they said all is fine. Network Services continues to fail.
My HR22-100 took much longer then normal for downloading the CE and reboot sequence. I think it took 20 to 25 minutes.
Network Services has always failed on most units. Jason has said it's something they will be working on later.
