Hughes sd-hbh tv antenna in question
papahoward
How do I send antenna signal from 'ant in' coax connector to rca video out jacks? I have no problem sending to 'output tv' coax out connector. Toggling the 'input' button on remote only changes the 'tv out', but not the rca video out.
Papa you can't send the signal to the RCA jacks, the SD=HBH dosen't have a TV tuner built into it. It is only an electronic A/B switch it passes the satellite signal or the TV antenna signal through the "F" fitting.
Thanks, boba. I had come to that conclusion and after thinking about it, it makes sense. I output the rca video jacks to my main tv and the coax output to the rest of the house. I was hoping I could use the sat receiver as an input device for my vcr, dvd, etc. and output to all my tv sets, which seems to work if I use coax in & coax out.
HU data stream is over/it's offical
D-VHS and Directivo
