I need everyone's help with TheList - Update your stations
KXXV DT2 is Telemundo.
WPXR and WPXK are both ION.
WHDT is an independent.
WJAN is a Spanish independent.
WBEC is educational (but not PBS).
WTVJ is NBC.
WRPX is ION.
KHCV depends on which subchannel Dish carriers. Check Wikipedia and the Dish Channel Chart and see which one they carry.
(Most PX locals are ION, with KPXJ being a key exception)
KNWS is an independent.
WGTV is PBS.
WEPX and WPXU (same station on two channels) are also MyNetworkTV affiliates in addition to ION.
WNEG is now an independent.
WFME is religious.
WUSI is PBS.
WCES is PBS.
WKBS is religious (// WPCB).
WHCT-38 is Azteca America.
KMTR-DT2 is CW.
WTPXD is just simply WTPX (a digital-only station even in the analog era). Again, ION.
KTVC is not RTN, and we really don't know. I think due to their new owners that they'll be religious. Former Equity station; shouldn't even be on here!
KEVU is MNTV.
ESBT (WSBT-DT2) is "SBT2", an independent service. It's on Dish because it used to be the UPN for the market.
WMLW is an independent.
ALSKA is a channel called Alaska Public Affairs.
WOAC should be listed as WRLM and WOAC. The latter are still their official calls but the former are being used on air.
WJYS is religious; WWME is an independent.
WHME and WHMB, along with KWHD, are World Harvest TV.
KBMT-DT2 is NBC.
KMCI is an independent.
KYMA-DT2 is LATV; KECY-DT3 is Telemundo; KECY-DT2 is ABC "ABC 5".
KSWT-DT2 is CW.
Most LPTVs with "DF" in them are Azteca America.
KTVW is Univisión.
There's my two cents (or twenty).
KTVC is an Independent.....its a AMGTV affiliate (same as KQUP Spokane)
Yes they will be changing to a 3ABN affiliate when it gets taken over but as of right now its still and Independent
also KQUP Pullman is IND
technically it is now called 360North
They have political things from Juneau some time...otherwise they show older PBS type programs or shows aimed at Alaskans
pretty neat channel
Everything is updated as of this message. Please do not include the station if the entry is correct.
Digi:
I checked them and there are some corrections or things to add in the Puerto Rico spot (49 at 110º):
Everyplace in the "Area" column that says "Aquadilla" should read "Aguadilla" with a "G" instead of a "Q". Aguadilla is a town in the northwestern part of the island. The FCC has it wrong.
WIPR is a PBS affiliate.
WLII is a Univision (UNI) affiliate
WJPX is a CaribeVision (CV) affiliate
WSJU is a SBS (Mega TV) affiliate. This was correct before...
I appreciate all your work. The List is a great resource. Thanks.
Digi:
7797 MPEG4 SD WCCV Rel. channel La cadena Del Milagro Arecibo.
Good JOB Digi!
WCTV - 9291 - CBS - Thomasville, GA
WTWC - 9292 - NBC - Tallahassee, FL
WTLH - 9293 - FOX - Bainbridge, GA
WFSU - 9296 - PBS - Tallahassee, FL
WTLF - 9295 - CW - Tallahassee, Fl
WTXL - 9290 - ABC - Tallahassee, FL
Didn't see any of these, so hope it helps (either that or I'm blind :eek:)
KMPH (FOX 26) Visalia-Fresno, CA
The repeaters are Merced-mariposa, CA
the rest of the Fresno area looks ok
KIVI is licensed in Nampa, ID. No national ABC? What do you mean?
I meant that KIVI was never associated with the national ABC channel that it is tied to, hence my post. Sorry for the bad wording. Thanks for updating the list. That was the only major national channel that wasn't yet showing up on the list for Boise area.
They were already there.... only had to fix the PBS one.
SatelliteGuys.US - Dish Network ALL
No 119 options
Any way to stop recording on tuner 2?
