installation problem
vdawgs22
12
i had 90+ signal for 101, 55% for 101 and nothing for 119... so i tried some tweaking.....
when i have 101 and 110 i can't get 119... if i swivel the dish a good amount to the left 119 will come in with perfect signal at an elevation of 33. and tilt of 64...
when 101 and 110 come in the tilt is 78 and the elevation is 24
2 problems/questions
the discrepency in elevation seems a little significant and clearly all 3 won't work at such a large gap
AND
when 119 was coming in although reciever read 95 signal the dish setup said failed when testing satellite 119...
any help would be appreciated
I'm making the assumption tht you have a Phase III dish. First off make sure your mast is perfectly plumb and level. Set the elevation and tilt for your zip code. You should'nt have to tweak the tilt or maybe very rarely. Most of your fine adjustments will be with the azimuth and elevation. Hope this helps.
FF / REW Issue HR-20 / MPEG-4
IR remote HR20 - HR10 interference
