Installation Question
larsh74
35
I have a customer that is interested in having Dish Network installed in his home. He wants all of the cables and phonelines to be run underneath his house and then brought up inside his walls. I am somewhat familiar with bringing the wire down the wall from the attic but have never tried bringing them up through the wall from underneath. Can anyone give any information on what type of drillbits should be used or tips on how to do this in general? Thnx for the help.
How large of an area underneath this home is it? If it's fairly decent sized...enough that you can actually stand in, I recommend using a flex-bit. Just a matter of making your cut-out in the wall, inserting your flex-bit, and drilling down thru. Before you retract your bit, simply attach your cables to the bit and pull back up.
522 Dual DVR problem
DP 311 Freezes on Check switch
