iPhone ring tones
stimpson
Miller Lite Tester
4,701
46
Benton, Arkansas
What's a good site to download ring tones for the iPhone? Also, what is a good program for making your own other that iTunes?
Try this one. Free registration, although to get the tones on the phone requires a little bit of workaround.
I wonder if you could just load MP3 tones on the phone and have it recognize them as ringtones. Anyone know?
If you have a mac it's very easy with garage band. you can import any mp3 into itunes and convert to aac , then import into garage band and edit anyway you like. then export back to the ring tones folder in Itune. It's been awhile since I did it but I think there is a lenght limit on the finished ring tone, maybe 20-30 seconds, but I'm not sure.
I've got a few that are several minutes long, all I did was rename a file from .m4a to .m4r and add it to the folder. Of course, nobody will let the phone ring long enough for me to hear the whole thing :)
i used the "rename" function in windows to do it :) Make sure to unhide "known extensions" first then just click the thing and rename it.
nothing, it just makes it easier for you to find "m4a" and change it to "m4r" if it was hidden.
I've read there are some technical differences between a "standard m4a audio file" and a "m4r ringtone file" - something regarding metadata - but every one I have tried just renaming has worked fine.
Here is what I get when I try this. It doesn't look the same as the link video shows or describes. None of my MP3 files have the "m4a" in the file name, and when I convert my 30 sec clip to an AAC format to rename it to a "m4r", the file shows up as unrecognizable. What am I doing wrong here?
Ok. Got it. Thanks again Pepper. I thought I had unchecked the "hide extension", but I didn't. Took care of that and all is good.
Should I upgrade my Iphone 3g to 3GS?
Apple kicks another app to the curb
