Is my line of sight good for FTA ? [Pics]
r4Nd.m
5
:hatsoff:
Hi, this is the view from my 4th floor balcony. I was wanting to get a 36" dish & a motor for FTA & I'm wondering if I won't be able to catch certain Sat's?
Thanks for your comments
I live in Montreal, Canada
:hungry:
:D
Nice picture, below are all the angles to the satellites. From there you will be able to work out the elevation / line of sight to the satellites that you can see.
You can make yourself an inclinomter........
http://www.exploratorium.edu/math_explorer/howHigh_makeInclino.html
Code:
         Latitude 45° 30.000'N Longitude 73° 35.000'W
                       Sat Name Sat Lng Az(t) Az(m)   El  Skew
                       Amos 1/2    4.0W 104.9 121.5  5.5 -42.6
                Atlantic Bird 3    5.0W 105.6 122.3  6.2 -42.5
                Nilesat 101/102    7.0W 107.2 123.8  7.5 -42.0
     Telecom 2D/Atlantic Bird 2    8.0W 107.9 124.6  8.2 -41.8
                     Express A3   11.0W 110.3 127.0 10.3 -41.1
                     Telstar 12   15.0W 113.5 130.2 13.0 -40.0
                   Intelsat 901   18.0W 116.0 132.7 14.9 -39.0
                          NSS 7   22.0W 119.5 136.1 17.5 -37.6
                   Intelsat 905   24.5W 121.7 138.4 19.1 -36.6
                   Intelsat 907   27.5W 124.5 141.1 21.0 -35.3
                  Hispasat 1C/D   30.0W 126.8 143.5 22.5 -34.1
                   Intelsat 801   31.5W 128.3 145.0 23.4 -33.4
                   Intelsat 903   34.5W 131.3 147.9 25.1 -31.8
                    AMC 12/T 11   37.5W 134.4 151.0 26.7 -30.1
                        NSS 806   40.5W 137.6 154.2 28.3 -28.2
                      Pas 3R/6B   43.0W 140.4 157.0 29.6 -26.6
                         Pas 1R   45.0W 142.6 159.3 30.5 -25.2
                   Intelsat 705   50.0W 148.5 165.2 32.7 -21.5
                   Intelsat 707   53.0W 152.2 168.9 33.8 -19.1
                   Intelsat 805   55.5W 155.4 172.0 34.6 -17.0
                          Pas 9   58.0W 158.6 175.3 35.4 -14.8
                       Amazonas   61.0W 162.6 179.3 36.1 -12.1
                     EchoStar 3   61.5W 163.3 179.9 36.3 -11.6
                      Rainbow 1   61.5W 163.3 179.9 36.3 -11.6
               Estrela do Sul 1   63.0W 165.3 182.0 36.6 -10.2
                   Brasilsat B2   65.0W 168.1 184.7 36.9  -8.3
                   Brasilsat B1   70.0W 175.0 191.6 37.5  -3.5
                       Nahuel 1   71.8W 177.5 194.1 37.6  -1.8
                      DirecTV 1   72.5W 178.5 195.1 37.6  -1.1
                          AMC 6   72.0W 177.8 194.4 37.6  -1.6
                          SBS 6   74.0W 180.6 197.2 37.6   0.4
                     Echostar 4   77.0W 184.8 201.4 37.5   3.4
                          AMC 5   79.0W 187.6 204.2 37.3   5.3
                      Nimiq 2/3   82.0W 191.7 208.4 37.0   8.2
                          AMC-9   83.0W 193.1 209.7 36.8   9.1
                   Brasilsat B3   84.0W 194.5 211.1 36.6  10.1
                          AMC 2   85.0W 195.8 212.5 36.4  11.0
                          AMC 3   87.0W 198.5 215.1 35.9  12.8
                           IA-8   89.0W 201.1 217.8 35.4  14.6
                      Galaxy 11   91.0W 203.7 220.4 34.8  16.4
                     Nimiq 1/4i   91.0W 203.7 220.4 34.8  16.4
                   Brasilsat B4   92.0W 205.0 221.7 34.5  17.2
                           IA-6   93.0W 206.3 222.9 34.2  18.1
                      Galaxy 3C   95.0W 208.8 225.5 33.5  19.7
                           IA-5   97.0W 211.3 227.9 32.7  21.3
                      Galaxy 4R   99.0W 213.7 230.3 31.9  22.9
                     Spaceway 2   99.2W 213.9 230.6 31.8  23.0
                DirecTV 1R/4S/8  101.0W 216.0 232.7 31.0  24.3
                          AMC 4  101.0W 216.0 232.7 31.0  24.3
                     Spaceway 1  103.0W 218.3 235.0 30.1  25.8
                          AMC 1  103.0W 218.3 235.0 30.1  25.8
                         AMC 15  105.0W 220.6 237.2 29.1  27.1
                      Anik F1/R  107.3W 223.1 239.7 28.0  28.6
                      DirecTV 5  109.5W 225.4 242.1 26.8  30.0
                EchoStar 6/8/10  110.0W 226.0 242.6 26.6  30.3
                        Anik F2  111.1W 227.1 243.8 26.0  30.9
                  Solidaridad 2  113.0W 229.0 245.7 24.9  32.0
                       SatMex 6  115.0W 231.0 247.7 23.8  33.0
                       SatMex 5  116.8W 232.8 249.4 22.7  33.9
                         AMC-16  119.0W 234.9 251.5 21.4  35.0
                     DirecTV 7s  119.0W 234.9 251.5 21.4  35.0
                     EchoStar 7  119.0W 234.9 251.5 21.4  35.0
          EchoStar 9/Telstar 13  121.0W 236.8 253.4 20.1  35.9
                     Galaxy 10R  123.0W 238.6 255.2 18.9  36.7
                      Galaxy 14  125.0W 240.4 257.0 17.6  37.5
                  Galaxy 13/H 1  127.0W 242.1 258.8 16.3  38.3
 Intelsat Americas 7/Echostar 5  129.0W 243.8 260.5 15.0  39.0
                         AMC 11  131.0W 245.5 262.1 13.7  39.6
                      Galaxy 15  133.0W 247.1 263.8 12.4  40.2
                         AMC 10  135.0W 248.8 265.4 11.1  40.8
                          AMC 7  137.0W 250.4 267.0  9.7  41.3
                          AMC 8  139.0W 251.9 268.6  8.3  41.8
                   EchoStar 1/2  148.0W 258.7 275.4  2.2  43.4
       Satellite Finder is (c) Copyright 2004, P. Lutus
You have a limited view of the Clarke Belt, the problem with balconies is usually whats above the dish more than whats in front of it.
PSB,
In your opinion, is it worth doing or should I absolutely have it on the roof? There is another balcony above me...
Sometimes the roof is the ONLY option. Even if there were nothing above you, you still only have a partial view of the Clarke Belt, then add to that the overhang. I would do a roof mount as you want to see as MANY satellites as you can after going to this bother. I think if you install on the balcony you may end up moving it to the roof eventually anyway!
The farther north you are the lower the dish needs to be so as PSB noted, the roof may be the only option. I have mine on the roof because my deck is on the North side of the house. Being in MN (45N 93.5W) the highest the dish gets is 38.5 degrees. If we were farther south, the elevation is like 45-50 which can clear much more :)
Invacom help!
G10R more problems...
