Just moved, can't have DirecTV, can't cancel?
ka1z0ku
95
Chucktown,SC
So my wife and I are current DirecTV customers, and just moved across base (we live in base housing on a Navy base), and the house we moved to apparently only has the ability to have one active coax line into the house (which is being used by Comcast for cable internet). The DirecTV installer we had come over to help us set up after the move said that he couldnt run another line or put in another outlet or anything of that nature for legal reasons, and the company who runs base housing is also refusing to help. We decided that instead of further exploring satellite options we'd just get digital cable, however DirecTV is now saying that "can't leave your contract without paying blah blah fees, its not our fault you cant get service, you can technically get satellite signal so we wont waive cancellation fees" etc, you get the idea. After talking to 3 associates and emailing the billing dept, we have accomplished nothing. Does anyone have any ideas as to what I can do to cancel DirecTV without paying $300?
wildbill129
1,273
Redding, CA
Can you get DSL instead? Then you could use the coax line for DirecTV if they would do a SWM LNB setup for you.
twizt3dsist3r
2,962
212
Pennsylvania, United States
I second this idea, you can then replace any internal cable splitter with a swm splitter. And in the worst case senario, you could diplex the cable/satellite, however you would be limited to 1 satellite line ever... so 1 tv, dvr with 1 line, high deff would be fine with the correct equipment, however you lose the ability to expand your system.
stonecold
3,487
Directv La La Land
Or do what I would do is drill my own damn holes where no one is looking. The installer off the hook all he did was put a cable through the hole. lol. But again I like bucking authority.
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
33,124
18,441
Cheshire CT
I find that hard to believe! ;)
jtwex
828
Embarrassed Bear
Having done the apartment shuffle in my youth I can say this is the best advise; all sorts of stuff out there too to hide the dish also if you're worried about that too.
WTguy
430
Use a flat line cable and go thru a window or a door jamb. No holes to drill and you can take it out when you leave.
This is the way to go, I did this with my fta system for awhile to a second floor window at our house until I had time to do something more permanent. There was no loss of signal but I do suggest using a window that you do not expect to be opening and closing very much (preferrably not at all).
twizt3dsist3r
2,962
212
flat wire is garbage with directv.... not sure if its still approved, but with high deff i wouldnt chance it at all.. OP never mentioned what kinda receivers.... or if swm is an option.
Portable Directv HD
Finding Sat 101 Difficult in the woods.
